[Mk2] [Turbo] Rad Fans coming on when car starts up, how to stop this?
gline
Post by gline »
The previous owner of my tubby has the radiator fans coming on immidiatly when you turn the key over, they only turn off when you turn the engine off.
How do I put it back to standard so that they come on only whne it reaches a certain temp ?
Reason I ask is because I eventually want to hook my chargecooler unit up and I want the chargecooler pump to come on at a certain temp.
Also is there any benifit to adding a SPAL fan to the cinquecento rad I have for the chargecooler? i will be mounting it in front of the engine rad
Razor04
Re: [Mk2] [Turbo] Rad Fans coming on when car starts up, how to stop this?
Post by Razor04 »
Are you sure its the rad fans? & not the intercooler fan? a common mod is to disconnect the engine bay temp sensor (attatched to underside of engine lid) this will put the intercooler fan into failsafe mode so it runs all the time. From ignition to switch off. The mod is to reduce heatsoak from the engine on the intercooler.
gline
Post by gline »
Razor04 wrote:Are you sure its the rad fans? & not the intercooler fan? a common mod is to disconnect the engine bay temp sensor (attatched to underside of engine lid) this will put the intercooler fan into failsafe mode so it runs all the time. From ignition to switch off. The mod is to reduce heatsoak from the engine on the intercooler.
yeh its definitly the front rad fans that come on as you can hear and see them when you lift the frunk bonnet.
paul port
Post by paul port »
He has most likely disconnected the temperature sensor from the front radiator... That would be the quickest way to do it... forces the Aircon/Heater ECU into a safe mode of operation
paul
gline
Post by gline »
Where exactly is it located? any pics at all?
paul port
Post by paul port »
On the Radiator :roll:
Seriously... Just lay on your back and look up, it's on the RHS if I recall
Pbgts
rad fans
Post by Pbgts »
Hi mate i dont think the old owner has switched the fans to run this way, ive got the same problem as you and its done my head in for over 3 months now. ](*,) Ive checked everything ,relays,switches,air con ,sencors,e.t.c has your air con stopped working ??
gline
Re: rad fans
Post by gline »
Pbgts wrote:Hi mate i dont think the old owner has switched the fans to run this way, ive got the same problem as you and its done my head in for over 3 months now. ](*,) Ive checked everything ,relays,switches,air con ,sencors,e.t.c has your air con stopped working ??
well the air coming out is warm so im assuming yes.
However I think i see the temp sensor unplugged near the fan, but i cant see where it plugs into.
Pbgts
Post by Pbgts »
The fan temp sencor is on the drivers side bottom of the rad its got 2 wires that fit into the connector ,ive tried two new temp sencors in the rad but still nothing so dont waste ya money on them
gline
Post by gline »
Pbgts wrote:The fan temp sencor is on the drivers side bottom of the rad its got 2 wires that fit into the connector ,ive tried two new temp sencors in the rad but still nothing so dont waste ya money on them
I can see the 2 pin connector , but i cant see where this goes into, il have to jack up the car and get under there. Wasnt gonna buy a new sensor, just plug the old one in, if it doesnt work i'll just have to live with thee fans on all the time :(
Also the IC fan is on all the time, so il have to check the engine bay sensor too. Man i must be eating a fair bit more petrol with all those fans on all the time :(
paul port
Post by paul port »
I should point out...
If the car has Aircon (EG an Import) then the sensor mounted in that hole is DIFFERENT to say a UK car Without Aircon - despite the connector being the same (If memory serves)
With Aircon: Sensor is a Thermistor 'Temperature Sender' - tells the Aircon ECU the temperature of the water
No Aircon: Sensor is a Thermostat-Switch - Simply switches on/off at a given temperature
Fit the wrong one in either car, and the fans will run continuously
Pbgts
Post by Pbgts »
#-o Looking at the wiring diagrams all 3 fans are linked ,ive checked the votage and the wiring continuity to all sencors and checked the earths , relays #-o My problem started one morning about 3 months ago i started the car and my 2 fans came on and stayed on ,it didnt happen after changing any parts or anything #-o my old switch works fine ive tested it in boiling water and it switches
Benmoore999
Post by Benmoore999 »
nothing to do with the aircon pressure sensor being unplugged in the frunk ? If you unplug that the rad fans will stay on all the time.
Return to “Electrical”
