[Mk2] [NA] Fault code
Grimmy
Post by Grimmy »
Fault code 43 flashing on dash anybody any idear it is a 3s-fe engine
karlosmr2
Re: [Mk2] [NA] Fault code
Post by karlosmr2 »
43
Starter Signal
No STA signal to ECU until engine speed reaches 800rpm with vehicle not moving.
Grimmy
Post by Grimmy »
Has anybody got a idear what i can try to get the car started i have checked the fuses all ready
karlosmr2
Post by karlosmr2 »
could maybe be the main lead, or starters xxxxx or some connector has come out...
DB1
Post by DB1 »
check the ignition coil, just to the right of the engine bay fuse box. mine corroded, due to a spilt in the side of it ....
they are on ebay here if you need one for 7mm leads, or for a 5mm, visit the sellers shop
http://cgi.ebay.co.uk/Toyota-MR2-MK2-SW ... 286.c0.m14
this cured my car and a friends from dodgy hesitation. mine was so bad it wouldnt start
Grimmy
Post by Grimmy »
I am getting a spark at the lead but the petrol is not pumping. pump is ok.
Has anybody got an idear what i can check next. Is there a cut out switch for the fuel pump
DB1
Post by DB1 »
No cut out switch, sorry
karlosmr2
Post by karlosmr2 »
mines doing the same now hahahaha
still runs and works as it should though :-k
