I can see it giving restiction issues at speed as it covers the whole IC
Am i right or wrong?
oBladeo wrote:hummm 30-40% i think you have that a little wrong
http://i343.photobucket.com/albums/o450 ... 01798a.jpg
jimGTS wrote:anyone who does these mods genrally has the fan on 24/7..
i run mine all the time as soon as the car starts to get warmer.
it pulls a vast amount of air through that fan.
you can literally place a piece of paper at the"entry" of the sidevent
(6inchs away from the fins on the ooutside), and it will suck it straight onto the ic.
now the fan is only going to be pulling air in at comparative low speeds, im guessing 20-30mph.
so anything below this, and its helping stop heatsoak.
this is an good advantage on the 1/4 when lining up.where theres lots of 0-5mph.
and i guess if on a track, where theres lots of stops and starts, getting to pits or whatever.
either way, as soon as that engine is shut down the car will begin to heatsoak over the next 30-40mins, and get extremely hot.turning on and idling the car helps when that fan gets going
(if you have it on a swtich)
then again i do have rogue lid fans to, they pull a stupid amount of heat out the bay.
refering to above 30 and to say 100 or whatever.yes the fan is made a bit redundant.
but if on, i really dont think to restrictive.
i guess the air blowing through the ic will outrun the fan, but the hole for the ic pipes are not behind it.
they run in the middle
(so before the fan), so that air from outside is running through the pipes before it exits the other side of the fins.
ive run with no fans at all over the last week and am seeing much higher temps than usual.10C infact.
