ST205 ECU for chargecooler pump control
Re: ST205 ECU for chargecooler pump control
Thats a good point ^^ If you have a st205 pfc why not instead of trying to fool it, fit a st205 gt4 chargecooler
What did you guys do with the chargecooler pipe that fouls on the coolant neck? I've heard some people cut them and weld them back, could you not just heat up and bend it out of the way?
- IMOC Committee
I cut it off and replaced it with a silicon 90 degree hose
I heated it up with a Propane Torch and twisted it around another 20 degrees or so.
It didn't distort or crack with heating it up then?
Seems the easiest and best way to do it.
Got to order my pump and rad tomorrow and then start painting the CC and think about brackets
Lefty1991 wrote:It didn't distort or crack with heating it up then?
No, I just applied heat slowly and only applied a small amount of pressure with a socket set extension bar inserted into the pipe.
That's great advice thank you.
I'm looking forward to getting it all done.
What sort of intake temps are you getting with the CC
Has anyone removed the level sensor on the chargecooler? How do you do it?
All you need to do is ground it .. its been done to my gt4 .
I don't mean remove it from the circuit, I want to pull it out so I can paint the core
Lefty1991 wrote:I don't mean remove it from the circuit, I want to pull it out so I can paint the core
Ow sorry mate
No worries thank you for the speedy reply anyway.
I just went out and had a look , its fixed to the chargecooler .. dont think i'd try to remove it .. sorry mate .
Lift up the rubber cover and unscrew with long nose pliers. 2 minute job.
Thanks a lot for the reply
Spin on whats been said, I wired a temp switch in and have a PWM speed controller running the base speed so it's always running a set amount I set to about 25% (which on normal driving never switches) then when the temp goes up to a set point it switches to full power 100% pump speed until the temp drops again, I have a full power override switch too on the control box when I go to shakespeare county etc.
see here:
http://www.fr10ker.co.uk/FR10KER/Site_v ... index.html
see here:
