You can see the fittings here:
So for everything all in, discs, calipers, pads and including VAT and postage what does it work out at roughly? I`ve just shelled out on coilovers and a few other bits but I will be looking to upgrade my brakes next, at the end of this month.
Most people would go for:
£431.69+vat for the kit which is the discs, calipers, brackets+inserts, bolts.
EBC Reds are£35.37+vat
Lines need to be confirmed but are probably£50.77+vat/pr
UK Zone 1 shipping is FREE for people who use a bank transfer, or£10.00+vat for people who use PayPal.
So the total for the front(via transfer) is
£517.83+vat
(£608.45 inc vat)
kingsley wrote:Keri,
Your brake upgrade looks very intersting but I have a few questions.I'm no expert in this area so I'm just asking because I would like to know the answers
- I need to change my front brakes anyway
(pads worn and one of the discs is warped) so now seems a good time to consider an upgrade.
I like the fact that you've considered retaining the correct front/rear balance with your kits.
I also like that your kit is a lot lighter than the OEM stuff because of the whole unsprung weight thing.
So.
1.I noticed your discs are a lot thinner than the stock ones.
Does this cause any problems with overheating, fade or warping? Also, how does this affect disc life
(in terms of wear limits)?
2.Do you have matching kits for the rears that still have a handbrake?
3.Are your calipers road sealed
(whatever that means)? I've heard that some race calipers aren't and that it can be a problem when they're used in winter with salt on the roads
(I don't know how much of an issue this really is).
Cheers,
Kingsley.
