I'm intrigued by the nozzle from the turbo-IC pipe as I'm pretty sure I don't have one.
JJ wrote:"I'm intrigued by the nozzle from the turbo-IC pipe as I'm pretty sure I don't have one.
Thinking straight, its a rev 3 thing..
its the feed for the a/c vsv on the rev 3.
which I think you've accounted for in the feed to the vac pipe
( afm to turbo
You should try doing a pressure test on the whole intake system.
manifold first.
pressurise it, see if theres any leaks.
Alternatively, pull the hose off the back of the afm, see if you can wedge it shut..
and pull one of the nozzles off and stick some air through it.
It'll save you trying to find a leak whilst the engine is running( noise
Know any mates with compressed bottled air?!
Get a fitting off it and do it that way
Shmed wrote:JJ, would my injector resistor pack cause any issues as to how much fuel is being put in? I had to re-wire it as it had been cut off.Is it likely that this would cause the car to constantly over-fuel?
Shmed wrote:I guess the fact that it revs up tells me it is fine inside.![]()
COPS?!?!
