The day started with installing the cup holder that I bought the other day.
Its a quick, simple and effective mod.
No difference when shut
And how it looks folded out:
Id rather the girlfriend has something to store a can in rather than drink in the car.
I then had the intention to build the rear suspension properly and fit it along with new braided brake hoses and brake lines
Unfortunately Kwik fit overtightened the wheel nuts when they replaced the rear tyres
A short trip later to a friend's house and they were all cracked off, although that was unfortunately half the day gone already
SO time to crack on.
Wheel came off to show the old set up;
I then ripped out the brake line to the o/s rear brake hose.
](./images/smilies/eusa_wall.gif)
First part of it removed
And the rest:
New parts ready to be made:
One end was made up, fitted to the original splitter unit and then traced through the original route
After lots of cussing, a hammer and some man power the old suspension joints were released
These two bolts took a good half hour even with the use of my trusty blow torch!
Anyway to cut a long story short the old unit got removed
It had seen better days and wasn't looking particularly healthy
Jack and I built up the new suspension
This then got fitted and even if I do say so myself it looked rather good
I also fitted the HEL braided brake hose to the caliper ready to be paired with the brake line which I trimmed down accordingly
It comes as no suprise that I finished off the brake line, joined it all together and secured the brake line to the suspension strut
I then made up a new bracket to hold the brake hose and brake line to the chasis.
Which after being bent into shape looked like this:
These brake parts arent going anywhere! lol.
The spacer then got fitted
The car got put back together and I used the new wheel nuts that are now on the front.
Exhausted and tired I went inside and collapsed into a little heap!
I havent re-filled the brake fluid or blead the system as it will encourage me to do the other side.
This week I intend to order new cancer bars and new rear calipers
Its then time for doing the dreaded polybushing! lol
Oh
Although it doesn't look like loads for today trying to undo bolts that haven't ever been touched on a 21 year old car is no meant feat and unfortunately takes its time! lol.
Until next time
