I think that you are completly right, it does need to stay retro, which is the main reason I decided against the autopista centre, as it just didn't look OEM.
Its a fine line between refurbishing, modernising it and then modifying it.
I definately want to stay more on the side of refurbishing and some modernisation than major modification.
I also want the car looking understated and sleek as oppossed to over the top or chavvy.
Today I managed to get the afternoon off work and it proved very productive
Although I recently replaced the headunit in my car for a standard one it wasn't working properly, and the cd section didn't function at all.
In short it had to go
I wanted a modern one that fitted in.
I bought a Clarion CX609E headunit.
It looks understated but has cd, aux, radio, mp3, ipod, bluetooth, phone connectivity, etc etc.
(basically all the mod cons) It was a 5 minute job and ironically one that I am most pleased with in the car overall:
Before
(looks oem but doesn't work properly)
New unit:
And installed:
It has numerous menu options and a huge variety of backlight colours.
I've currently got it set as bright white to match my dash lights
I am so so pleased
I then fitted an engine bay sticker thats appropriate to my car:
Then the real fun began
- I thought that I would make the most of the weather and do a job that I've been wanting to do since I bought the car!! I bought some underbodyseal, a paintbrush and some axel stands.
That resulted in the following happening:
I started to rub it all back
(this took a long time to strip off years of dirt and rust).
Here it is part way through.
The transformation complete on one side:
My current springs look horrendous!! But at least the waxoil looks good everywhere else:
Next year I want to replace the entire suspension setup but for the time being I am tidying it all up until I can properly afford it.
Ideally I want to replace with original Toyota units, but fear that this will set me back quite a bit!!
I then did the other side rear wheel area
(neither was quick)
Complete:
I'm borrowing a large jack from a friend and tomorrow I'm hoping to jack the car up as high as possible and waxoil all the relevant parts on the underside
(weather permitting)
I also have 11 parts waiting to be delivered
Although those will stay a suprise
Oh and hopefully next week I will fit my spal fan as I am on holiday from work for the rest of the month
