Si, I don't agree about the turbo timer thing.
Sure, it'll cool down a bit, but as long as the engine is running, the engine is heating the coolant.
MR2 engines push out some fair heat.
Regardless of how much cool down I gave, on a hot day, I still used to get the gurgle.
Think of it this way, how long does it take for the coolant to get to proper operating temp from cold? In contrast, my Golf diesel could be idleing for AGES from cold and the temp needle will barely budge.
I have to put it under some load before it'll start heating the coolant system up.
SiCook wrote:A lekky water pump helps out when driving too because it always runs at the same speed.
The only other main benefit for me
(parking the car on the street) is I can officially leave the car with the pump and rad fans running and walk away
- can't do that when the engine is running because IIRC a cat with a running engine in a public place has to be attended at all times.
Today, at an Evo dyno day, I noticed that the RC developments demo car was running the same electric water pump I mentioned earlier.
Now, THAT car is a monster, however it does run purely on methanol, which means that the engine runs SO much cooler than when on petrol.
So much so, that they struggle with getting high enough EGTs to drive the turbo properly!
SiCook wrote:I have been wondering how many horses the engine driven water pump uses
- perhaps with running at fixed revs the lekky pump may be more efficient than if it were driven by the engine
- so perhaps it frees a few more horses.
Or how much the oil pump and alternator consume to run! Someone once told me that had he could see a difference in power on the dyno from merely putting on the car's heater.
Obviously, this means that it's putting more load on the alternator.
If you were so concerned of such losses though, you'd get the biggest gain from a dry sump setup, IMHO.
