Replacing stock REV5 wheels with new - what suits beige/champagne?
cosmos
Rev5 wheels
Post by cosmos »
Hi Matt i also purchased my Rev 5 Tubby import in 2003 and it did sport some Work wheels and since have bought Work vs xx 17" 8" + 9" et35 which is the limit for flush fitting, camber bolt kit would be good for my rears but always i shy away from fitting at the thought of arch rolling regards splitting the paint not least because i had a full respray £3,000+. Archenemy seem to be good for some and not others.
Good Hunting...
2barGee
Re: wheels
Post by 2barGee »
sonic1999 wrote:True gee man the stock wheels had cheap nasty tires on with tall profiles the 17 inch now run 40s which I feel best suited for feel and handling
Tall profiles on our cars arnt a bad thing. It's pants tyres like t1r's
See below.
http://www.imoc.co.uk/forums/viewtopic.php?t=15623
aussieGT
Re: wheels
Post by aussieGT »
See below.
You say T1R's are pants?
2barGee
Re: wheels
Post by 2barGee »
See below.
In the wet they are. Pretty good dry grip though.
Rob66
Re: Replacing stock REV5 wheels with new - what suits beige/champagne?
Post by Rob66 »
I will need to replace mine soon, and I'm told the only option if I want all 4 the same and I do are T1Rs..
Plenty of options for fronts apparently it's the rear size which is a pain to get.
2barGee
Post by 2barGee »
Rob66 wrote:I will need to replace mine soon, and I'm told the only option if I want all 4 the same and I do are T1Rs..
They do R888's get them!! Awesome tyre :thumleft: But a bit hardcore for road use.
Rob66
Post by Rob66 »
Cheers will get some prices :D
matt5cott
Post by matt5cott »
Great discussions guys thanks, I'm just taking my time and seeing what's out there, regarding 17s ruining the handling, perhaps this may be the case, but I'll take the looks option this time and go with the bigger rims :)
matt5cott wrote:Great discussions guys thanks, I'm just taking my time and seeing what's out there, regarding 17s ruining the handling, perhaps this may be the case, but I'll take the looks option this time and go with the bigger rims :)
Mine is on 17s, and the handling is spot on. It definitely doesn't ruin it the handling.
2barGee
Post by 2barGee »
If your not going to track the car 17s will be fine. :thumleft:
Get some pictures up when you get them fitted! Black / dark wheels would suit your motor imo 8) :thumleft:
matt5cott
Post by matt5cott »
Wheels obtained!
8j +32 - 215/40/17 front
9j +38 - 245/40/17 rear
Looking at dropping the height with tein springs when the wheels get fitted, what does everyone think, likely to rub?
HighwayStar
Post by HighwayStar »
Likely to rattle the fillings out of your teeth… :shock:
R
matt5cott
Post by matt5cott »
HighwayStar wrote:Likely to rattle the fillings out of your teeth… :shock:
R
Thanks for the tip, been reading up and they sound a nightmare!
I'll look at the 30mm springs, and others :)
I've Apex on mine. -30mm, recommended. Tein's are reported as being rather hard.
SonicSW20
Post by SonicSW20 »
Know a few people using Spax springs, they seem to rate them.
matt5cott
Post by matt5cott »
Thanks, this is on stock suspension, I'm worried about it looking like a tractor if I don't lower it :lol:
30mm like the Apex I'm worried is "not low enough"
Teins sound like a crashy nightmare
40mm (such as spax) sounds like it might be too much for stock suspension!
Input definitely appreciated, I'm getting new droplinks all round too.
SonicSW20
Post by SonicSW20 »
I wouldn't fit *any* lowering springs to old stock suspension.
Even the youngest stock suspension is now 16-17 years old. Any lowering spring will likely kill them off anyway.
Do it once, do it right - buy new struts, top mounts etc as well.
matt5cott wrote:Thanks, this is on stock suspension, I'm worried about it looking like a tractor if I don't lower it :lol:
This is mine on 17x8 ET38 215/40/17 front, 17x9 ET38 245/40/17 rear, on Apex -30mm springs:
In addition, I'm on Ohlins struts. Sits just right in my opinion. No rubbing problems whatsoever, including lock to lock. :thumleft:
