If anyone fancies popping over to say hello
aw11rally wrote:I'm not sure those cams are much use to anyone, too little lift for big power and too much duration for sensible running.If you're building an engine to exploit that much duration then a little machining to allow 10-11mm lift would be a no brainer.
Maybe I'm wrong.
Lauren wrote:Finally after much wiggling, the bottom end is free! Here is Mark posing as usual!It really was a royal PITA to separate the block from the gearbox.
vashy wrote:Lauren wrote:Finally after much wiggling, the bottom end is free! Here is Mark posing as usual!It really was a royal PITA to separate the block from the gearbox.
ah it´s not as bad as when you try to connect it back up again![]()
Icsunonove wrote:I think I would have removed the engine and gearbox as one.Then you can put the engine pointing vertically upwards and then lower the gearbox onto it.
Not quite sure why Lauren descided not toremove the gearbox
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming'stop raping me'
should have got a picture of theLauren wrote:After we got it going I took it for the obligatory fairly sideways test drive.![]()
