[Mk2] [Turbo] Starting build
Re: [Mk2] [Turbo] Starting build
Yes, they will make another girdle but you will have to send your block down as it has to be custom fitted.
http://www.stanroseengineering.co.uk/
Did all the work
I will get photos later today if I get the chance.
Now the cost.
.lol I had the oil squirters fitted, the oil feed to the balance shafts plugged, the dip stick hole plugged all that with the girdle made from EN8 steel is going to be
£1200
+ VAT.
It may be cheaper for you as they know what they are doing now.
The pistons are being designed by John Pimentel of Race Engineering and will be CP, around
$1300 a set
The same piston as used in this but I will have 8.0:1 comp.
http://www.youtube.com/watch?v=MaRaBnZl ... ojmyuLeYqF
Rods will be custom made by Arrow Precision to John Pimentels design to match the pistons
Did all the work
Now the cost.
- IMOC Committee
Watching with interest Bob
IMOC-UK
- the only club to win
'Best Club Stand' at JAE more than once, and twice in a row!
yeah spoke to pat in december about the 5s block in his celica and he said he was working on something new.
890whp guess thats about 890 at the flywheel in uk
my blocks exactly same as yours from underneath, im not goin with squirters and ive tapped and blocked the balancershaft assembly oil feed
surely a girdle could be universal?
i was thinking more like 30-50 quid? 1200?lol
The girdle has to fit around the block and on the top and the bolt holes of the main caps.
The main caps have to be milled so they are all the same hight then the girdle is fitted to the main caps with not even o.ooooo" gap.
The metel I think was over
£100.00 then 3 days on the mill
There is only one way to do thing right and it all costs money
bit cheaper girdle, but read description as it needs a few parts.
Still seems good value though.
http://twosrus.com/catalog/product_info ... cts_id=297
All made in one piece just under 40mm thick
Sending off the cam shafts for balancing later this week
http://www.vibrationfree.co.uk/motorsport.htm
Pistons being made now, should have them in 4 to 6 weeks.
Rods also being made, not sure how long they will take yet.
One great thing about not having a woman around, I have the block, crank block girdle in the living room keeping nice and warm
Girdle looks very nice!
Can't wait to see this finished!
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile.
Crank in place
Nice tight clearance to take the oil off the crank
The important part, how the girdle clamps down onto the main caps
Now have to wait 6 or 7 weeks for the pistons and rods to come.
Time to put the roll cage in, build the close ratio gearbox and wire up the Motec ecu, oh and the 044 fuel pump in the tank
I'm enjoying watching this build, I'm building my 5sgte not to quiet the same power level with my small gtx3076, lol.
Nice work Bob
Nice work Bob
Was MR2Turbo1991, but now changed name.
5SGTE Forged Build 2011/12
Build Thread: http://www.imoc.co.uk/forums/viewtopic. ... nniversary
Re: build
calum4492 wrote:very nice![]()
when do u think she will be ready to roll?
do u not fancy a few 1/4 mile runs 2 see what it can do?
I have not been drag racing since back in the 80s when I was supplying most of the nitrous systems to the cars and bikes.
If at the end of the season if we have time we may give it a go
Will you be up for doing totb with this bob, if it's ready?
greeny wrote:Will you be up for doing totb with this bob, if it's ready?
Yes as long as we do not have a sprint on at the same time.
Do you have dates?
bobhatton wrote:greeny wrote:Will you be up for doing totb with this bob, if it's ready?
Do you have dates?
http://totb.co.uk/
Looks like that weekend it free, just have to see if and how the car is running.
Going to try this turbo out next year if it all stays together.
http://www.youtube.com/watch?v=GvVFxLkm-so
Wow
- this really is a labour of love
I'm very impressed.
Keep up the good work
- I can't wait to see it in the flesh when its running properly
I'm very impressed.
This should be on its way to the dry sump builder later this week.
For anyone building a higher power than stock engine this is what should be done to the pistons.
You should never just fit what comes in the box, that is just the starting point.
See how smooth everything is on the left hand piston
