I had the lot mate.
.pops and bangs all the time still
.to the point where I can do it on command by a wee blip of the throttle just after the over run.
.but jeez it used to almost kangaroo sometimes.
.all I did was.
attach the bleeding tubes to the 2 taps up frunk.
.1 on the bulkhead and 1 on the right hand side of the rad.
.pipes tie wrapped up in the air, unscrew the taps a bit and release the water filler cap in the engine bay, not take it off just undo it a bit.
Start the engine and let it run with the heating set to full hot.
.and after a few mins the bubbles just worked their way through an up/out of the pipes.
.deffo checking the coil is worthwhile, I'm gonna check my spare according to the bgb later.
Peter from S-bits.
.a hugely helpfull fellow.
.offered to send me replacement parts for you to use as diagnostic tools.
.for a nominal fee and postage.
A prob with diagnosing stuff on a forum is you get everyones probs all at once and what they did to fix it.
.very helpfull but can also be overwhelming and make the prob seem worse than it is.
.always seems to be the simple fix that works.
.if the water temp sensor is too hot or cold due to it not being in water.
.it will be working correctly but sending the wrong info to the ecu for smooth running.
