UPDATE
With most of the things done now i decided to crack on with the safety apsect of things.
I popped over to corbeau factory wich is only down the road for me, the manager mark kindly donated me 6 stess plates for my 5 point driftworks harnesses big thanks to him, i decided to stick with the dw set instead of the takata's as to keep the colour scheme.
On my return from the factory i logged on here to see a cusco 6 point rollcage for sale, perfect timing so 3 texts and a day later i had the cusco cage in possession, It has added strut bars on the rear and on the passengers side, big thanks to tim earp for driving 5hours to deliver it to me
After test fitting it, it accured to me that with the bars being to close my head etc padding would need to be fitted as the cage could do me more damage in an accident then the crash would when used on the road with out a helmet, so saved my self some money on spraying it orange, i sourced some high density FIA approved padding in orange from speedwaymotors.com so will be fitting them as soon as they turn up.
Pics enjoy
After fitting the cage etc i refitted the bride firewall carpet and it just looked to much so decided to revert it back to standard to look how it was intendid a track car.
All fitted
Only 250 more running in miles todo, then i can fit my fueling bits injectors rail pumps lines etc, i am also swapping my apexi power fc in favour of a syvec S6 supplied and mapped by ryan at 2bartuning, reasons being is the lack of safety features
(knock control etc) the apexi has being so dated, i also want to run wideband and do away with the stock o2 sensor wich the apexi cant do.
I was originaly goin to be fitting a motec m400 but with the Motec you have to pay twice the price to get even close to everything the Syvecs has, heres some of the reason i am goin Syvec now instead
The MoTeC unit has a good hardware setup but I feel the software lacks even compared to an AEM.
Like no Knock control built in
(requires external box), Large changes cause the unit to reset due to memory allocation designs, Map Cut has a 1SEC delay as standard! which can be the difference between 1.4bar and 2bar of boost.
(This is terrible as it should be Milliseconds like the S6), No ability to be able to change the map through graphical view.
Interpolation tasks are basic and most things you need to pay extra for.
Extra Features which also boost the S6 product
- Full Traction control which is miles ahead of RLTC or Motec, Uses steering angle or Lateral G based sensor against road speed of each wheel to measure slip.
Then retards timing or cuts fueling to create missfire to compensate.
But in retarding timing it watchs EGT levels and compensates for that if goes above preset.
Levels of slip can then be changed in the cabin through Cal switch which has 8 positions.
- Knock control as standard which monitors every cylinder.
If one cylinder starts becoming really noisy all of the sudden due to say a valve or injector issue it will shut it down
- Full DBW support with added blip features on changing down etc
- Full Quad cam VVTI control
- Internal Datalogging
(which you dont have to pay extra for lol)
- Full Closed loop Lambda with sensor failure sensing.
- Full Closed loop Boost control
(best i have seen)
- Sensor failure or other parameters will causes limp home mode
- Engine trips and warm up limps
- Full nitrous or water injection table
- 8 Position cal switch to set different levels of boost, anti-theft mode, Valet limiter for the likes of MOTs etc, 4 switchable maps on the fly for fuel and ign and lots more.
Going into the engine trip and warm up limps more.
The S6 has lots of inputs for the likes of EGT sensor, oil pressure
, oil temp etc.
With each sensor you can set trips and limp.
I.e on Oil Pressure i set the engine not to start until oil pressure is seen and if it drops below a set value while the engine is running to cut engine.
Another one i use on all the TVRs that run S6's is not allow the engine to go above 3500rpm until the oil temp is above 60c.
All these features is what has made the high power supra world and most of the time attack cars far more reliable.
Look out in the for sale section soon for people looking to buy an apexi pfc with hand commander
