I think you need to wind you're neck in Mr Angry!
E-manage ultimate.
again, it's another ECU fooling system, it takes the signals destined for the ECU, and modifies them to make the ECU do something
*different* to what Toyota intended.
When the VE goes over a certain level and the ECU would normally go OPEN on the injectors, it will change that signal, preventing the ECU knowing the true load on the engine.
It's controlled-lying.
It's also
£400.
It needs botching into your existing loom and them mapping.
It's certainly not plug-n-play.
The whole reason this ECU is so attractive to the people on this Forum, is because it gives us the opportunity to actually control the REACTION the ECU has to it's inputs, not just modify the inputs to OBTAIN the REACTION WE WANT!!
For example, quoting the e-manage ultimate.
.can remove the speed limiter on a vehicle
(may not work on all vehicles)".
They actually write that!
*may not work on all vehicles*.
Oh great!
Well, the one in Jeremys' ECU
*does* work! As does the knock light, and the MPG indicator, and the safe-mode map notification, the injector cycle, throttle position, RPM etc.
And then, when you want less fuel to go in at WOT 6500rpm so it doesn't crank the injectors to 100% you TELL IT to, you don't PRETEND it's at less load forcing the reaction!
Hehehe, this is circular.
I'm starting to repeat myself.
Piggybacks are not good.
They may have had good results, but they are superceded now by better equipment.
If this project ever completes, this project will be in the column marked
"better equipment".
