Well to check for calipers seizing, put your hand on each wheel after a run and one should feel warmer than the other
- presumably the one that's making the noise.
All that should be needed is to regrease the pin etc, not replace.
As for the play, it really depends how it feels and exactly where it is, I can imagine the side to side
'play' would be slight wear in the rack etc but if its more of a knocking then that's not good.
Not sure what up and down movement you've done, could be top mounts worn
- put your fingers on the topmount nut, and lever the wheel up and down with a plank of wood or something.
do you get any knocking when driving?
Assume you've checked your wheel nuts are tight?
