Wheel Alignment
si2040
Wheel Alignment
Post by si2040 »
Hi Guys,
Had my MR2 go in for a wheel alignment computerized and when I got back home I've found they have done it based on a MK3 MR2...would the adjustment settings be the same?
Also does anyone have a print out of their alignment settings or what they should be...I can't find any on the net.
MR2 Night Fox
si2040
Re: Wheel Alignment
Post by si2040 »
can any one help??
MR2 Night Fox
genuinita
Re: Wheel Alignment
Post by genuinita »
stock settings for rev2:
JohnnyC
Re: Wheel Alignment
Post by JohnnyC »
Found these, hope they're correct...
Rev1
Rev3+
si2040
Re: Wheel Alignment
Post by si2040 »
thanks guys but im a bit lost to the reading as mine is all in degrees. If you guys can have a look to see if this makes sense and matches that would be great :) Thank you for your help so far.
My Current settings are:
Left Front
Toe 0deg04'
Caster 3deg43'
Camber-0deg48'
Right Front
Toe 0deg02'
Caster 3deg14'
Camber -0deg13'
Total Toe 0deg06'
Steer Ahead 0deg01'
Rear
Rear Left
Camber -1deg27'
Toe 0deg12'
Rear Right
Camber -1deg06'
Toe 0deg11'
Total Toe 0deg24'
Thrust Angle 0deg00'
MR2 Night Fox
genuinita
Re: Wheel Alignment
Post by genuinita »
the ° symbol is degrees
the ' symbol is minutes (a 60 unit subdivision of degrees)
so you can compare your camber & castor direct to the toy' documents JohnnyC posted. i don't know how to convert the toy' toe measurements to degrees though so you could use the ones i posted (i'm pretty sure theyre correct :pray: !) or the rev3 ones, which will reduce oversteer somewhat
front castor is a bit high (left out of spec)
front right camber a bit low
everything else looks ok ish
i'm certainly no expert so i dont know how important it is if somethings not close to ideal or just out of allowable spec
heres my last printout to compare- they got it very close to what i asked except for the castor (apparently mine isnt adjustable):
si2040
Re: Wheel Alignment
Post by si2040 »
great thats the type of print out I have do you have anything on cross camber?
MR2 Night Fox
Moo
Re: Wheel Alignment
Post by Moo »
Dinos' recommended settings for any Mk2 :thumleft: Scroll down this thread for a printout of all the settings you will need for a nice stable ride :)
http://www.imoc.co.uk/forums/viewtopic. ... highlight=
genuinita
Re: Wheel Alignment
Post by genuinita »
cross camber is the difference in camber between the R & L wheels on an axle
your figures: (-0°48' FL) - (-0°13' FR) = 0°35' front cross camber
(-1°27' RL) - (-1°06' RR) = 0°21' rear cross camber
- the smaller the number the better, although some people would set a touch more neg camber on the left side of the car to help it drive straight when driving on the left side of crowned roads (as we do here in UK) but it will tend to pull right on other surfaces (middle, right side of road, tracks etc)
