found a nut on my driveway anyone know what it could be off?
JohnnyC
Re: found a nut on my driveway anyone know what it could be off?
Post by JohnnyC »
There's only one nut (AFAIK) on the undertrays, and it don't look like that.
Leon.
Post by Leon. »
JohnnyC wrote:There's only one nut (AFAIK) on the undertrays, and it don't look like that.
Mine did, maybe it wasn't the original part, or maybe yours isn't :oldtongue:
JohnnyC
Post by JohnnyC »
Every single one of my undertray bolts (+nut) is proper Toyota monkey metal - apart from the gaffer tape where the 3 bolts used to be :oops:
Mr2_NA
Post by Mr2_NA »
genuinita wrote:maybe off the exhaust manifold studs?
I was thinking the same :thumleft:
Hard to see if they missing though, especially with the heatshield on.
RobCrezz
Post by RobCrezz »
check the tops of your suspension struts
SFLee
Post by SFLee »
check induction kit where it mean the bodyworks, my dissapear a while back
RobCrezz wrote:check the tops of your suspension struts
It's only a small nut prob 12mm.
DB1
Post by DB1 »
i lost one from my exhaust heatshiled a couple of months back, didnt even notice it was gone until i went to deliberately remove it.
it was the upper manifold shield bolts. there are two. so losing one did not make it rattle or anything either.
if not the only other one i know that size is on throttle cable holder thingy, whiich comes off the side of the block, toward the firewall of the engine bay
C50
Post by C50 »
i thought the shield is held by bolts not nuts :-k
could be exhaust manifold or turbo>manifold but these tend to have nuts with a split in them
did you check droplinks?
Leon.
Post by Leon. »
I thought of another possibility.
Your left b0ll0ck?
mr2nut123
Post by mr2nut123 »
RedMR² wrote:longshot I know :-k
Reversed the car off my drive and found a solitary nut:
Image Replaced With URL For Quote http://i3.photobucket.com/albums/y98/Re ... 0_0054.jpg
Don't know what it's off, found directly under my car. I have put a 5p coin next to it for size.
Thanks for any suggestions. I'm pretty worried about what is under my car without a nut
Thanks for any help.
I've seen those before!! I'm fairly sure they're off the metal firewall panel inbetween the inside of the car and the downpipe.
Steve-O 2007
Post by Steve-O 2007 »
Surely a Manifold nut will be bigger than 12mm (1.2cm) Thats a tiny nut and i bet theres a few more missing anyway ;)
i wouldnt worry too much, have you seen the amounts of bolts left over from engine in / out / rebuilds that just get binned?
was the bolt at the rear or front of the car?
Steve-O 2007 wrote:Surely a Manifold nut will be bigger than 12mm (1.2cm) Thats a tiny nut and i bet theres a few more missing anyway ;)
I've had a look at the heatshield/firewall shield/undertrays etc. Those nuts are all different.
I have no idea where it's from and guess I will never find out.
Oh well, the search endeth :mrgreen:
Steve-O 2007
I recently had my front Bumper strip / trim off and it looked similar but dont think they would undo that easy.
Just have a scan around the engine bay at the things mounted to the chassis
I bet its not even off your car :), Someone probably kicked it while walking and its landed in your drive :mrgreen: #-o
Another one of my thoughts
Trying to search for the location for a nut, that doesn't belong on my car. Good call #-o :lol:
CM1GT
Post by CM1GT »
had any mates round who like to play jokes? i used to throw rusty old nuts and bolts under my housemates elise just to watch him worry :evil:
silverhawk160
Post by silverhawk160 »
CM1GT wrote:had any mates round who like to play jokes? i used to throw rusty old nuts and bolts under my housemates elise just to watch him worry :evil:
He he, thats a bit harsh but funny
Tomm
Post by Tomm »
i doubt it would be anythng important, Like sid before its probably a shoulder bolt from some thing like a heat sheild or retaining clip or similar.
I highly doubt it would be a ARB, Exhaust mani, topmountbolt or anything like that.
i also find it odd that it has fallen off on your drive? Surely it wouldhave come off whislt you was driving around and there was a steady and constant vibration going through the car?
If it is from your car i woldnt worry yourself about it, Its most likley to have come from some thing insignificant otherwise it would have been dont up so tight you need to call Ronnie Coleman round t help you get it off!
