MK1 Head bolt Socket help......Please
Scooter
Post by Scooter »
Guys and Girls, i'm after info on what socket i need for the female socket required to remove the head bolts on a mk1
What size and the best place to get one would be good........
.......i'd just buy a set, but i did that for the male type needed for a VW polo's head and they didn't fit past the cam etc and so i ended up borrowing someone elses anyway!
LimeyMk1
Re: MK1 Head bolt Socket help......Please
Post by LimeyMk1 »
3/4' 10mm double hex deep socket is the best for the head bolts, you can get them singley from Halfords. Otherwise I believe it's a SST from Toyota or a female Torx socket but I couldn't find one when I was looking last year.
Chris
Scooter
Post by Scooter »
many thanks, i'll go to the local Halfords and see what i can find....
p_j_smith
Post by p_j_smith »
as just posted, yes double hex head.
May also be called bi-hex head, dont get the standard hex type (6 sides).
System-G
Post by System-G »
You'll probably need a breaker bar too, they are well tight :roll:
PW@Woodsport
Post by PW@Woodsport »
probably a typo by limey but not 3/4" drive.....3/8ths drive. :D
Scooter
Post by Scooter »
Ta did wonder about that bit!
Icsunonove
Post by Icsunonove »
Yes, 3/8" drive is what you need, 1/2" drive sockets won't fit.
LimeyMk1
Post by LimeyMk1 »
:oops: Typo, sorry!
