Got a Rev1 which seems to be draining the battery overnight.
All I can think is that it's got a red flashing LED
Are there any common faults I should be looking for???
Thanks all
Battery meter was reading just below 18V
jim-mapps wrote:Push started it
SFLee wrote:get a mulitmeter, about£10
in maplin
switch the multi meter in dc and amp select the range
unplug the negative from battery
connect the multimeter in series and complete the circuit again
this should show how much amps you car is draining( should be in milli amps range)
nofearmadbiker wrote:i used the solar panel and car started ok, ive charged battery so its at full strengh so when im in work i put the solar panel on the dash and on days off, hopefully it will help me see how it goes otherwise might have to invest in a new battery![]()
