The Winter "Diesel On The Road" Thread
Re: The Winter "Diesel On The Road" Thread
You're always gonna be far less likely to get into a horrific mess in a FWD car IMO.
tonigmr2 wrote:To be fair I don't think ALL tubbies have no feel..
.I've had a couple that were nightmares and one or two that were lovely.
I think it's entirely down to suspension and set-up!
But finding the sweet spot is harder on that car I think than a little FWD.
T
Well, my current mission is to make my tubby more supple and friendly.
- Lauren
- IMOC Committee
T
But in standard form.
There are plenty of other cars in stock form that have feel.
As you know I used to have a 200bhp BMW.
2020 GR Yaris
- Circuit Pack
Lauren wrote:
But in standard form.![]()
Lauren/Toni, what do you think is necessary to improve the handling of mk2s? I've probably driven 6 or 7 mk2s with various different setups and although I couldn't tell you how they behaved at the limit, they all rode and steered differently.
The two that had the best ride were on standard suspension and the other on Super Streets.
I've got Cusco strut braces and will be using TRD top mounts, but what else would you do? Will a custom geometry setup
- Lauren
- IMOC Committee
The two that had the best ride were on standard suspension and the other on Super Streets.I can't afford the Teins hence I'm going for stock springs and either UK spec struts from MrT or Yellow Billies if I can stetch.
I've got Cusco strut braces and will be using TRD top mounts, but what else would you do? Will a custom geometry setup(using camber bolts) be a big improvement over factory settings?
Well out of all the mk2s i've driven the only one that I actually thought handled pretty well was Toni's 24K yellow tubby which was stock engine wise but was on Teins which were obviously well setup.
I've not ever owned a MK2 so can't really comment on the other options.
Another good option would be to get some tuition on a handling day/trackday.
I think once you get used to how the car reacts and how to handle it with the correct inputs etc it does take away a lot of the worry of such
2020 GR Yaris
- Circuit Pack
If your going for new parts I bet there's not much difference in price between them and a set of TEINS.
As Lauren said
- the two better handling MK2s I have had have both been on Teins
- the yellow car was Tein HAs!
So I wouldn't bin them if I were you, I'd go and get a full alignment done first.
.and tbh I think MK2s handle better on 16s.
T
T
About
Plus, there would also be a saving on my insurance premium of about
tonigmr2 wrote:As Lauren said- the two better handling MK2s I have had have both been on Teins
T
Thanks, Toni.
My wheels are 16in Sparco
Ah, well if you can't adjust the damping you probably have a very skittish car, as they are bl00dy hard on some settings.
The yellow billies and springs seem a good option then tbh.
For a fast road set-up probably more than adequate.
Good choice on wheels IMHO.
I have the Tein Flex on the TRD with EDFC
- love
'em.
But agreed it is not a cheap option.
T
T
Matt, when I priced up a set of OE shocks, springs, top mounts and basically everything to put my suspension back to standard I think it worked out at MORE than a set of TEINS and TEIN top mounts.
Although me may be talking about different TEINS here, the ones I was looking at would have been around
£800 all in with the top mounts and springs.
Save confusion here's what I was looking at.
Yellow billies
£500 will need springs
+ top mounts will end up around
£800 by my estimation?
http://www.roguesystems.co.uk/forms/Product.aspx?ID=414
And via Camskill
- set of Superstreets with top mounts for just over
£800
http://www.camskill.co.uk/products.php? ... 0s611p2810
Yellow billies
And via Camskill
tonigmr2 wrote:I'd go and get a full alignment done first.
T
Go to see Tony at WIM, I had my mazda setup by him and its great.
But just reading your damping adjustment is f'd you still need new shocks, they could all be on different settings.
p.s.
matt_mr2t wrote:Matt, when I priced up a set of OE shocks, springs, top mounts and basically everything to put my suspension back to standard I think it worked out at MORE than a set of TEINS and TEIN top mounts.![]()
Although me may be talking about different TEINS here, the ones I was looking at would have been around£800 all in with the top mounts and springs.
Yellow billies£500 will need springs
And via Camskill- set of Superstreets with top mounts for just over
£800
Hey, Matt
I've just bought a set of TRD top mounts from Fensport and that cost me
That's a great price for the Teins from Camskill, but although I really like them, I actually prefer the even softer ride from stock springs.
steve b wrote:tonigmr2 wrote:I'd go and get a full alignment done first.
T
Go to see Tony at WIM, I had my mazda setup by him and its great.Once I get a set of shocks for my MR2 it'll make its way to him.
Great thing is he taylors it to you, asks what sort of driving, how you want it to react and sets it up appropriately, if after 2 weeks or 2 months you decide it could be better he'll have you back and tweak it for no charge.
p.s.New shocks means new alignment, throwing a set of shocks on with out an alignment is a waste of time.
Cheers, Steve.
Re damping
Question on ball joints and bushes: worth changing regardless, or only bother if badly worn?
Bushes I would always definitely say yes to
- especially if you're on the stock originals.
I've always been amazed by the transformation just changing those can make.
Ball joints not unless they are noticably worn IMHO.
T
T
Re the
'lack of feel' in the Mk2's steering, chat to Andy
(Luthor1) he has an easy little mod that will get rid of it.
Limeymk1 wrote:Re the'lack of feel' in the Mk2's steering, chat to Andy
I believe that would be the steering column mod?
I read about that a while ago
mattcambs wrote:Limeymk1 wrote:Re the'lack of feel' in the Mk2's steering, chat to Andy
I believe that would be the steering column mod?![]()
That's the puppy.
While you're at it give him a boot from me to write it up for the knowledge base.
Hi,
yes'm Mr Limey Sir
Andy
yes'm Mr Limey Sir
Andy
luthor1 wrote:Hi,
yes'm Mr Limey Sir
Andy
I would be interested in this mod?
