[Mk2] [Turbo] how hard is it 2fit a 4 to 1 exhaust manifold??
scoobyslayer
Post by scoobyslayer »
i love the look of a 4 to 1 manifold, it well within my budgit to buy, but im not sure about fitting costs? is it easy enough 2 fit myself or do i hand it over 2 the more than capalbe hands of rouge motorsports? what power gain can i expect?
i had a jap speed decat pipe fitted, does that change anything about fitting it?
haha its a rev3 3sgte btw
any response is apreichiated :)
http://cgi.ebay.co.uk/TOYOTA-MR2-CELICA ... 240%3A1318
thats the link 2 it, looks fookin georgous!!
Mike N
manifold
Post by Mike N »
Its just a general fitting job only made difficult by the amount of seized nuts and bolts you encounter.
When you buy one I would check the mounting flang faces for straightness using a steel rule or straight edge as my ebay item was miles out, I ended up machining both faces.
Wipe the manifold clean and free of any fingerprints or grease before start up!
Steve-O 2007
Re: [Mk2] [Turbo] how hard is it 2fit a 4 to 1 exhaust manifold??
Post by Steve-O 2007 »
apparently them cheap ebay ones crack / split easilly so I would stay away from it and keep the stock one unless your going for over 450bhp (I thikn the stock ones good for upto that or it might of been 500bhp)?
C50
Post by C50 »
my old work buddy had one and it cracked.
Post by Martin F »
your barely going to notice any benefits on a rev 3, maybe go for one with an uprated turbo or 500 bhp +, standard one works well enough below these power levels (or so i have read)
the one in the link won't fit a rev3 anyway and the xs power brand is like ending up with a plastic cup when you go to the pub and ask for a pint, don't waste your money and the following heartache...
the answer to the original question though is ....
as above, come across seized bolts etc...arpita
if you have worked on cars and are quite confident then its not hard, maybe a 2-4 hour job as long as you have the right equipment :thumleft:
revturbo
Post by revturbo »
it's a real ar$e of a job!
I gave up after snapping a bolt and it's sat in the garage ever since!!
-:[KM]:-
Post by -:[KM]:- »
Marf
Post by Marf »
As nice as a blingy stainless manifold is as said above they crack, better off with a nice strong cast manifold.
-:[KM]:-
Post by -:[KM]:- »
Marf wrote:As nice as a blingy stainless manifold is
And they don't stay 'bling' for long either.
