any reason why a downpipe would go from 2.5inchs, to 4inchs, to 3-3.5inch???
jimGTS
Re: any reason why a downpipe would go from 2.5inchs, to 4inchs, to 3-3.5inch???
Post by jimGTS »
mattcambs wrote:
jimGTS wrote:so its a CAT, not a straight through downpipe locky?
prob is is it enough to pass uk emissions, lol, may be enough to pass the jap ones.
thanks
only one way to find out.
I reckon this is a right result for you Jim seeing as on a rev 5 you would need to pass the stricter emissions test.
haha, see if you dont ask, you dont find out, lol.... \:D/
this could have saved me a massive heartacke come mot time...
as i would of had to have done something similar (ie weld a cat in)...
result indeed...
now just need to test it out.
Razor04
Post by Razor04 »
Jim whats the condition of the welding like? just curious,
mattcambs
Post by mattcambs »
definitely one hell of a car you have there :D 8) :thumleft:
jimGTS
Post by jimGTS »
theres alot of bracing on the turbo, downpipe and screamer....
so id hope it was half decent anyway.
lockys96
Post by lockys96 »
yes its a cat, mine flowed 570hp at 1.6bar, so flow isnt an issue
jimGTS
Post by jimGTS »
Cheers locky for your PP help.
Must be a pricey item to if it's still capable of flowing that sort of hp.
mattcambs
Post by mattcambs »
decents CATs aren't cheap. I had to replace the CAT on my Civic the other day (just failed MOT emissions: boo). Honda one is £400 :shock: Decent pattern part was nearly £300. So I went for an Ebay special - £60 :shock: and it didn't fit without serious cutting and welding :lol:
