Fitting Exhaust
tom_snelling
Fitting Exhaust
Post by tom_snelling »
Is it essential to fit new gaskets where the exhaust bolts to the manifold?
SuperRedMR2
Re: Fitting Exhaust
Post by SuperRedMR2 »
yes
tom_snelling
Re: Fitting Exhaust
OK thanks.
Down the motor factors it is then!
MartG
Re: Fitting Exhaust
Post by MartG »
Coating them in Firegum when fitting also helps to seal the join :wink:
un1eash
Re: Fitting Exhaust
Post by un1eash »
I wouldnt use firegum, its not really needed and if it drys quickly without compressing the gaskets it can work lose and cause leaks.
crazylegs
Re: Fitting Exhaust
Post by crazylegs »
save yourself a trip and try these
http://cgi.ebay.co.uk/TOYOTA-MR2-MK1-4A ... 286.c0.m14
i can vouch for them ! :whistle:
un1eash
Re: Fitting Exhaust
Post by un1eash »
If these are anything like the ones jinxy supplys then they are better then the toyota ones, they fit better and are slightly thicker.
Gad
Location: Castle Donington, home of fast cars and strange festivals...
Re: Fitting Exhaust
Post by Gad »
...Anyone experience alot of white smoke shortly following an exhaust change?
Fitted mine yesterday and just been out for a proper run and when stopped at traffic lights or the like it's smoking a fair bit!
Certainly wasn't doing it before the swap...
Could it be burning exhaust paste maybe? Seeing as we might've been a little over zealous on the application of it...
un1eash
Re: Fitting Exhaust
Post by un1eash »
White smoke is usually water so i'd give it a few miles as it may just be burning in. Its surprising how much moisture can get in the exhaust.
Gad
Re: Fitting Exhaust
Post by Gad »
Could be I guess, it's second hand so goodness knows how long it's been sat around while the guy's been breaking his car.
It's just a little worrying sitting at traffic lights as smoke (or perhaps, steam) bellows out behind you!
un1eash
Re: Fitting Exhaust
Post by un1eash »
It could be oil on the exhaust, this can take a couple hours to clear.
RowanMR2
Re: Fitting Exhaust
Post by RowanMR2 »
I also had a lot of white smoke coming from the manifold when I replaced it the day before yesterday. It also smelled nasty, seemed to be the heat shielding tape on the starter wiring harness that rested against the new manifold, check that it is clear or you could burn it.
