[Mk2] [Turbo] Intercooler, PASS YOUR JUDGEMENT!!!!
Pirate
Re: [Mk2] [Turbo] Intercooler, PASS YOUR JUDGEMENT!!!!
Post by Pirate »
platmatt8 wrote:
-If your kit comes with the jubilee clips make sure you DON`T over tighten them.
Hmmm you got the worst kind of clips , they are really bad not only for keeping things tight but as you said over tighten and they break. I'd get hold of these type
platmatt8
Post by platmatt8 »
JeffD wrote:Well done Matt for doing it yourself. Only tthing I'm wondering though is the high pitch whisytle you mention - I think that will be a boost leak on one of your pipes - wopuld be worth checjking security of all the hose clips/connections. If in the near future you car appears to have the turbo "switched off" it will be a pipe popping off! :-(
Shouldnt be whistling...
LOL well if i`ve got a boost leak it`s doing some good then, thanks Jeff i`ll have a check tomorrow if it`s not raining but the sound doesn`t get louder on full chat but disappears so i`m thinking it just might be a bit of turbulance :thumleft:
platmatt8
Post by platmatt8 »
Pirate wrote:
platmatt8 wrote:
Pirate wrote:or shall i see keep an eye on it
What keep an eye on my intercooler?
Have the brackets snapped on you personally?
see = Say , duh silly me #-o
LOL, me speak good england i do #-o
I`ll possibly look at new clips in the future but for now untill they go wrong i`ll stick with them :thumleft:
JeffD
Post by JeffD »
Is it "proportional" to the turbo spooling ie. can you play the turbo on and off and the whistle comes on and off in time with it?
I had a very similar problem with mine when I first fitted it and it was the pipe working its way off then just popped off eventually leaving me with what felt like a turboless car.
platmatt8
Post by platmatt8 »
Well jeff i`ve got a bit of boost leak just on one small bit due to me rushing and wanting to get on the road (didn`t tighten it up fully #-o ) I`ve still got the same noise so defo just got to be change of equipment :thumleft:
Nails
Post by Nails »
Got mine fitted today, didnt take too long, I removed the air con pump while I was on too as the rest of it Ive already removed, took about 5 hours with plenty of tab/dinner and tea breaks.
Im only running around 11psi (no boost controller but have a RSR exhaust and decat) but it defo feels like its pulling stronger to the redline.
Tiny
Post by Tiny »
mine arrived today the jubilee clips are Crap to put it mildly fitted in about 5 hours taking it steadily but the pipes just keep popping off at 12psi.
If i tighten them any more they will start to cut into the pipe and strip the thread on the clip.
gonna email him and ask what he will do about this because at the end of the day they are not fit for purpose. [-(
platmatt8
Post by platmatt8 »
I do agree there not the best, if your pipes are popping off @12psi you might have situated the clip on top of the lip thats supposed to stop this.
On the defence of the jubilee clips though every body seems to use them
Berk (pics borrowed for gtschris)
http://www.gtschris.com/store/catalog/0046_large.jpg
Greddy
http://www.gtschris.com/store/catalog/0019_large.jpg
HKS (bad pic)
http://www.rpmgarage.com/RPM/t1068-SW20 ... 280917.JPG
I`ve just bought some silicon self adhesive/moulding tape to wrap around pipe under the hose they`ll never pop off then :twisted:
platmatt8
Post by platmatt8 »
Right well i`ve re-fitted my IC pipes wrapping silicon sealing tape around the hard pipes i`m going to say it`s a must i struggled to pull the silicon hoses off without the clamps!!!!
I`ve fitted the stock ic fan and i`m pretty happy with it sucks nicely throught the new ic,
Also i`ve fitted and ic water spray :thumleft:
