As a continuation of a group buy currently running on various other European MR2 forums we extend an offer for purchase of SW20 front anti sway bar reinforcement plates.
A well known weakness on SW20 MR2s are the front sway bar mounting points.
This picture depicts
![Image](http://i294.photobucket.com/albums/mm101/mrgen3turbo/swaybareinpoints.jpg)
These plates are made in Australia.
For comparison
ST:
Australian:
For the same function this is quite a significant weight saving I think you will agree.
Installation is straight forward and can be accomplished by the backyard mechanic providing you have suitable equipment to safely jack and secure the front of the car.
Two versions are available, mild steel with zinc plating to resist corrosion and stainless steel.
We only have limited pairs left:
Stainless Steel: 55 GBP per pair
Zinc plated mild steel 35 GBP per pair
These are being distributed via Germany, postage from Germany to you with be an additional cost.
Zinc plated mild steel version
![Image](http://i294.photobucket.com/albums/mm101/mrgen3turbo/plates-1.jpg)
Various pictures of stainless steel version fitted:
![Image](http://i294.photobucket.com/albums/mm101/mrgen3turbo/SSA42161.jpg)
![Image](http://i294.photobucket.com/albums/mm101/mrgen3turbo/platesfitted-1.jpg)
![Image](http://i294.photobucket.com/albums/mm101/mrgen3turbo/SSA42170.jpg)
If you would like to buy a pair in this group buy, leave your forum ID as per below
Stainless Steel
1)
Zinc Plated Mild Steel
1)
2)
3)
4)
5)
Group Buy closes Sunday 10th August.
Thanks for looking.
