It has MOT to 28th Sept this year and MOT to end of Sept too.
Oct 1992 K reg rev2
Just under 106,000 miles.
No history other than current MOT and a few bits the previous owner did.
New forlife coolant with full flush done by Luke at Pacific works.
Luke also changed the offside handbrake cable.
The car had new discs and pads when I bought it 2 months ago! The brakes are spot on all round.
Engine/G-box:
The engine is not the original engine.
The oil pump gasket is leaking and needs replacing.
The valve shims are noisy.
There is a small bracket missing that helps keep the accelerator cable in situ
It does have a new rocker cover gasket though!
It runs and drives perfectly.
There are no knocks or rattles.
Previous owner changed the head-gasket.
It's had a reckon gearbox fitted too which you can see.
I have had a compression test done by Luke at Pacific works and all cylinders are spot on.
The car is totally standard.
The exhaust is fine and has it's CAT pipe in place.
There is a chip on the pass.
There is a small crack on the drivers side too.
Had it inspected by my local bodyshop too and he said it would not fail as it's not in the area considered dangerous.
T-bar seals dont leak as I siliconed them!
Fog lights have been removed but will go with the car.
The rear suspension frame has been changed by the previous owner too.
The car has half leathers in great condition for their age.
The car has a Sony MP3/CD stereo
It also has had a beesting aerial fitted.
The red bodywork
The rear spoiler is not super red.
Wheels are in good condition with only slight kerbing scars.
All 4 tyres are excellent with lots of tread
All electrics working.
Luke and Harry at Pacific Works will confirm all this info is true!
I need to sell the car asap so make me an offer please!
The car is too good to strip for parts but I will have to see about that!
As said.
Im wanting
Pic here
www.imoc.co.uk/forums/...e_id=13537
Please ask me any questions.
I can post up more pics at your request.
PM me and I can email you direct if you wish.
Cheers all.
Steve
