i need a new wiper blade but looking at them the arm screws to the blade which looks like its riveted, so i take it i have to get a blade from toyota which is going to cost the earth cant just go halfords and buy just normal say 16" blade and swap over any help would be apreciated
Should be able to just replace the blades mate. I got two new Bosch ones from Halfords a few weeks ago.If you are unsure they will do it for you.
IMOC - winners of JAE best overall club stand 2010, 2013, 2014 & 2017! 1994 GT-S T-Bar 397bhp with NOS *sold* 2016 Porsche Cayman 981GTS 347bhp Flat Six
hi i went to replace mine from a 1991 model.
The arm was so rusted that i couldnt put the new blades and bracket back on the wiper arm due to corrosion.
A quick trip to halfords made me decide to go to the scrappy.
90.00 TO GET A FULL SET OF CORRECT FIT ARMS, 10.00 FROM THE YARD!!!
Bloody Halfrauds
although another route would be to replace the standard screws with a couple of approriate self tapping screws. just an idea if money is tight
hi this is what my wiper looks like is it right or has somebody changed it, as you can see it screws to actual arm does not clip on like most wipers do thats what makes me think its going to cost a bomb
mine were the same as that. the actual clip part that slides on to the end of the arm doesnt get damaged or corrode. but the wholes on the arm, where the screws go through corrode really easily.
i replaced mine with 2 arms from a burnt out mr2 turbo that was at the local scrap yard. didnt cost much at all, and the loop (for holding the blade) on these are a bit better as incoperated in the arm itself.
no fiddly screws and very quick to replace.
