For sale is my Black F-reg Mk1 T-Bar.
As stated, this is a genuine black car, rather than one that has been re-sprayed black, as can be verified by the paint code on the chassis plate.
I purchased this car around four years ago, and it was my daily
As well as the problems mentioned above, the car has also succumbed to the usual Mk1 ravages of time, as follows:
Rusting of both rear arches
Some rust to front left wing/arch
Front right wing has worse corrosion
Corrosion above the windscreen and next to the T-Bar seals in 2-3 places.
Corrosion at base of A-pillars, and some around door switch on drivers side B-pillar.
The drivers seat
To begin with, I did keep the battery charged up by starting it regularly and allowing it to warm up, but last time this was tried, the starter motor had stuck and I was unable to.
Good points about the car are that it is pretty much standard and hasn't been messed around with or modified.
I have tried to list what are the most obvious points to me and be as honest as possible, although as is always the case, there are bound to be things I've missed/over-looked.
While the car still looks very presentable in the pictures, and could probably be patched up and put back on the road without too much effort in my honest opinion should really be viewed as a project as it really does need a lot of restoration work.
I would suggest that the car would need to be collected on a trailer due to the amount of time it has stood.
Am looking for offers around
Here are some pics.
I work shifts, but will get back to you as soon as I can, and am free most weekends.
Car is located in Norwich.
If anyone is interested, either reply on here or pm me.
PS If someone would be kind enough to direct link the images and let me know how to for future reference, I would be most grateful
PPS Here is a direct link to the entire albums, which contains a few additional pics:
http://s36.photobucket.com/albums/e22/AndyA74/F649OBP/
http://s36.photobucket.com/albums/e22/A ... F649OBP02/
