well i've been running one for sometime.
There xspower
The problem is you'll need a screamer pipe and oil feed and return also as the turbo is only oil cooled and not oil and water.
If you haven't got a EBC don't even bother getting this kit!
Also if you think you can strap this kit straight on and drive like a nutter your wrong as it needs to be bedded in for at least 500 miles
