[Mk2] [Turbo] Wharped my discs i think how can i stop it from happening again.
2barGee
Post by 2barGee »
I have got rev3 standard discs and brembo pads at the front. I did a track day about a month ago and now when i brake at hight speed i get some vibrations through. Soi am guessing i have wharped my front discs!!!
Now i was going to fit some carbotecs with some new rev3 discs but will the same thing happen again???
Or is its something else??
Dan :thumleft:
Extubby
Re: [Mk2] [Turbo] Wharped my discs i think how can i stop it from happening again.
Post by Extubby »
Hi
What make std discs are they. Could be that they are of bad quality metal.
I have Carbotechs on mine and am running std discs. I am very hard on brakes and have not had any problems even from high speed braking.
rev3kid
Post by rev3kid »
when you finished on your track day did you apply the hand break near enough stright after you had finished your run??
2barGee
Post by 2barGee »
rev3kid wrote:when you finished on your track day did you apply the hand break near enough stright after you had finished your run??
hope didnt put the handbrake on at all. Its coming from just the front as well??? :-k
Perhaps they are not the standard toyota disks on the front???
Are camskill ones decent??
Cheers dan
greeny
Post by greeny »
Are they new disc's youve fitted ?
2barGee
Post by 2barGee »
greeny wrote:Are they new disc's youve fitted ?
No the car had standard disks with brembo pads when i bought it. Since then i have done one track i bought some carbotecs but did not fit them as the brembo pads had loads left on them so i thought i would just kill them and fit new disks and pads.
The pads have still got enough on them for another track day but i am getting the vibrations at high speed when brakeing???
System-G
Post by System-G »
OK...
If the discs were warped, you would also feel a pulsating under gentle or prolonged braking too.
If you're only getting juddering under hard braking, it would sugest ball joints, bushings, droplinks etc...
Is the juddering felt through the pedal only or the pedal and steering?
2barGee
Post by 2barGee »
System-G wrote:OK...
er..... the juddering is just through the pedal mate, its only under hard or long breaking i feel it. :-k
turbomax
Post by turbomax »
try this should sort it out no problems
http://www.frozensolid.co.uk/
regards max
System-G
Post by System-G »
Hard to say for sure, but I guess the discs could be warped, the pads wearing unevenly or possible have a calliper sticking slightly:-k
Put your new pads and discs on. Follow the Carbotech bedding in proceedures and you should be fine. If the symptoms are imediately apparent, then look at the suspension components.
Whilst doing the disc/pad swap over, remove the rubbers & slides and give them a good clean out . Lube up and refit using something like Budweg Calliper Lubricant or the Mintex CeraTec stuff (avoid copper grease at all costs). Check the pistons are free moving too.
HTH :thumleft:
2barGee
Post by 2barGee »
[/quote]
HTH :thumleft:[/quote]
I will order some front standard rev3 discs then. I think cam skill are the cheapest??? Or is there another company i could use???
turbomax
Post by turbomax »
drive around a bit and then get out see if discs are very hot this would tell you if caliper is lazy and sticking
System-G
Post by System-G »
I have always found Brakes International very good for OEM equivalent parts. They also supply the Budweg Brake Lubricant. Phone them get pricing and then ask for MR2 club discount :wink:
As you're a premium member also look here:
http://www.imoc.co.uk/forums/viewforum.php?f=58
SevenR
Post by SevenR »
I bought my car and the discs/pads were quite new. they warped, so I put a new set on from Brakes International. They eventually warped again after several thousand miles. After some searching about I discovered th hubs may have been warped and in need of a re-skim. So, I bought some EBC grooved/drilld discs and Greenstuff pads. I also asked the fitter to check the hubs before fitting. He forgot, and since then my discs have warped again. Bloody brakes!!!
Harry
Post by Harry »
Touch the top of each 'caliper' the really hot one Is sticking. If sticking that wheel will have heaps of brake dust on the rim.Eliminate this one.
System-G
Post by System-G »
You may not want to touch calllipers (sticking or not) after a run - you could land up with serious burns :whistle: :oops:
You can feel any heat differences through the alloy wheels.
Harry
Post by Harry »
True. :mrgreen:
Bender Unit
Post by Bender Unit »
Whats the worry, just sounds like the discs are slightly out of true. Just keep using them until the pads are dead and replace with new pads / discs.
Uneven hub faces and incorectly torqued wheels can also cause disc warping from what I have heard.
Harry
Post by Harry »
incorectly torqued wheels can also cause disc warping from what I have heard. :-k
That's Interesting...I am fussy on my wheel nuts being torqued to 120 nm.
2barGee
Post by 2barGee »
Bender Unit wrote:Whats the worry, just sounds like the discs are slightly out of true. Just keep using them until the pads are dead and replace with new pads / discs.
Hi mate :)
Well i am at cadwell park on the 30th so going to kill the pads then bin the discs and put new (standard discs on) with carbotecs :twisted: :twisted: I am going to but the discs this week and take the pads and discs with me just in case :D
