Mobil 1 10w-30 fully synth
biscuitsbrown
Post by biscuitsbrown »
G'day peeps
does anyone supply or know of anyone or anywhere who can supply MOBIL 1 10w-30 Fully Sythetic engine oil as its fairly new from Mobil 1 but as usual the UK always seems to be the last to get it!?!
I've tries Halfords, Partco, Uni-part, Autosave, even Toyota but nowhere seems to be able to get hold of it!
Please let me know, greatly appreciated, regards Stu
:D
Jonty
Wrong market
Post by Jonty »
I think you'll find that Mobil 1 10W-30 isn't marketed in the UK. That might explain why it's so hard to find. If you want to run with M1 then consider 15W-50... but it's not cheap stuff. Worth it though in my oppinion, as engines are expensive... oil and filters are cheap. :)
If you don't own a Turbo, perhaps go for something in a semi-synth flavour. Cheaper too.
Regards,
Jonty.
biscuitsbrown
Re: Mobil 1 10w-30 fully synth
Hi Jonty,
Cheers for takin the time to reply mate! Yeah I guess you're probably right, its obviously not available here I've tried everywhere! I ended up gettin Mobil 1 15w-50 which is what i've been using up to now, just wanted to stick the Toyota Japan's recommended 10w-30 in but hey, I want doesn't always get I guess! :cry:
I always use Fully Synth wouldn't dream of using anything else for a turbo!
Regards Stu :D
couldnt_think_of_a_name
Post by couldnt_think_of_a_name »
go for redline or motul instead mate .
bidtowin
Post by bidtowin »
Is Mobil 1 15/50 available in Halfords?
Ross
ANDY FINDLAY
oil
Post by ANDY FINDLAY »
i am doing a oil change soon am using some scotwest 5-30w fully synth on my turbo it is approved by bmw,merc,porche so i guess it good oil is the grade ok but
raptor95GTS
Post by raptor95GTS »
i just shoved in some Mobil 1 0-40W in the tubby both that 15-50W from halfords
