[All] [Generic] Toyota ForLife Coolant - rip off? or quality?
shabz
Post by shabz »
Is there a reason they can charge us over £15 per 5L?? Its pricey, but i'm wondering if there's any point in it or not...?
If i save £20 on coolant now by buying some cheaper halfrauds stuff and my rad blow up in a year or so then its obviously not a wise saving :D
Your thoughts on forlife? and the best alternative for the price?
steve b
Re: [All] [Generic] Toyota ForLife Coolant - rip off? or quality?
Post by steve b »
The halfords red pre mixed is the same as forlife.
Quigonjay
Post by Quigonjay »
we've seen cylinder heads go due to years of using crap coolant and would only reccomend forlife
shabz
Post by shabz »
so your saying the halfords advanced stuff is no good?
Quigonjay
Post by Quigonjay »
shabz wrote:so your saying the halfords advanced stuff is no good?
it is claimed above the halfords stuff is the same as forlife, i wouldnt know personally as i've never seen it
Dale_V
Post by Dale_V »
why not just use forlife, its not a huge cost, and its not going to need changing for years.... :)
Driftlimits Performance
IMOC Affiliated Company
the new pink stuff is £32 for 5l :shock:
steve b
Post by steve b »
Well, if tin A says ethylene glycol 15% in distilled water and tin B says ethylene glycol 15% in distilled water and A costs £50 and B costs £20 what would you call the person who bought tin A? ;)
jimGTS
Post by jimGTS »
rich?
FreeFall
Post by FreeFall »
jimGTS wrote:rich?
:lol: :clap:
dannyroids
Post by dannyroids »
£32 for 5l!! :roll: if you wanna be ripped off and pay that go ahead! Rather excessive if u ask me. :?
king_ginge86
Post by king_ginge86 »
i got four from fensport for around £60 i think :cry:
is that expensive for forlife?
Charged
Post by Charged »
Halfords red stuff for me... and I've used it for many an MR2 coolant change :thumleft:
shabz
Post by shabz »
is this the right stuff?
what ratio coolant to water to use? all it says on the back is no more than 70% coolant
and is it ok to mix it with the forlife thats already in my system? the halfords stuff is pink in colour
dawolf
Post by dawolf »
My mechanic says that any ethylene based coolant is just fine. I'm sure that 'Forlife' is essentially the same stuff and I think it's wrong that dealers try and glorify their products to make them sound superior. I used plain water in my old N/A for over a year and it never caused a problem.
User avatar
Lauren
Post by Lauren »
dawolf wrote:My mechanic says that any ethylene based coolant is just fine. I'm sure that 'Forlife' is essentially the same stuff and I think it's wrong that dealers try and glorify their products to make them sound superior. I used plain water in my old N/A for over a year and it never caused a problem.
DING. Any ethylene based coolant is absolutely fine.
Just one point I wanted to make, its not called 'forlife' anymore its called; longlife.
3sgte
Post by 3sgte »
worth noting that although any ethylene glycol based coolant is fine, it is preffered to mix it with de-ionised water .which is essentialy what forlife /longlife /halfords premix is .
the de-ionised water just helps reduce electrolitic corrosion between dissimilar metals such as metal headgaskets and aluminum heads .
we had a batch of marine engines with blown headgaskets very early in their life which were being run with ethylene glycol and tapwater which set up corrosion and rotted the headgasket sealing ring and pitted the head .using a premixed glycol and de-ionised water has stopped the problem
Dale_V
Post by Dale_V »
£32 for 5l? think you are being bent over. I buy genuine toyota forlife coolant, 5litres is £15 MAX
go look yourself! £15 for the green/red coolant and the new PINK stuff is twice as much because it's made to last 100,00miles
mrfil13
Post by mrfil13 »
£32 for 5l is painful but when most cars require much less coolant than our MR2s you could see how they justify it. £96 for our cars is prob just abit OTT, especially considering 100,000 miles will outlast the rad etc and need to be drained anyway.
But anyway, the toyota longlife stuff for me.
