[Mk2] [Turbo] water temp gauge
owai
Post by owai »
Hi i've owned my rev2 turbo for 2 weeks now.
and was just wondering when letting the car warm up it only goes a quarter of the way up is this normal or is there something wrong?
it has an xs power side mount intercooler in place of where the normal intercooler went not sure if this makes a difference.
doesn't seem to be any other cooling mods done.
any ideas would be gratefull :)
iblis
Re: [Mk2] [Turbo] water temp gauge
Post by iblis »
Sounds like the thermostat is stuck open
owai
Post by owai »
easy job to fix? where can i get ahold of them and how much do they cost...o dear more problems :P
jimGTS
Post by jimGTS »
the intercooler has nothing to do with your water temperature....
it generally not a good idea to let the car sit there and get up to temperature..just creates heatsoak...
if the gauge doesnt go over 1/4, id say you need to replace the temp gauge sendor/sensor...
cheap, easy to do, if its not that, possibly thermostate, bit more expensive, and a bit tougher to do and takes a good while long...(as you have to rebleed the system to)...
dawolf
Post by dawolf »
With the thermostat you normally see the gauge dropping right down whilst driving along and then rising again when stopped in traffic. As stated try checking the temp sender.
owai
Post by owai »
no dont get me wrong i don't just let it sit i drive my car as a daily driver so don't have time to just let it sit i just drive it to work shifting just below 2k .
well i hope its an easy fix.. if you were me would you stay off boost completely then untill this is fixed? (i bviously bought the car for the turbo but dont mind granny driving as theres way to many speeed cameras anyways)
where can i buy replacement parts OEM? without going to mr T
Thanks for your helps guys guess i should have posted this up sooner!
cherdyboy
Post by cherdyboy »
ive had same thing on my car since i got it about 6 months ago (mainly the needle sits at the quarter mark, sometimes a little higher or lower), and i have been boosting around every day so i hope that it doesnt cause any damage...!!!
Anyone know if it should be fixed in a hurry (after 6 months that is?!)....
Slarty
Post by Slarty »
A tip for diagnosing if it's the thermostat that's stuck open is this:
Try to drive the car around town, so it's under load but there's not too much airflow going through the radiator. Then stop somewhere safe with a newspaper lol, and let the car idle for 10 mins or so. Might even be less if the weather is warm.
If the temperature gauge comes up to half way, the thermostat is stuck open. If it still doesn't move it's more likely to be the temperature sender.
hth :)
iblis
Post by iblis »
Slarty wrote:A tip for diagnosing if it's the thermostat that's stuck open is this:
hth :)
Spot on :thumleft:
jimGTS
Post by jimGTS »
cherdyboy wrote:ive had same thing on my car since i got it about 6 months ago (mainly the needle sits at the quarter mark, sometimes a little higher or lower), and i have been boosting around every day so i hope that it doesnt cause any damage...!!!
yes it should....
you wont actually be running at full power at all cause the ecu still thinks the car is cold and youll be running on the ecus cold start maps....
owai
Post by owai »
i think my problem is the tempreture sender anyidea where i can get them? had a look on camskill but couldn't find it. though i may do the thermostat as well as there pretty cheap to get ahold of.
but my problem doesnt seem like a thermostat one :(
please help me find a temp sender so i can fix it at the weekend!
jimGTS
Post by jimGTS »
get from toyota, they are only like £10-15...
owai
Post by owai »
http://www.camskill.co.uk/products.php? ... 5s605p4331
cheers might go see toyota tomorrow.
but is this what im looking for?
any write ups on installing it or is it pretty straight forward?
jimGTS
Post by jimGTS »
owai wrote:http://www.camskill.co.uk/products.php? ... 5s605p4331
thats the ecu controlled one, not the guage one...
straight swap, may loose 1/4 of a cup of coolent when swapping them over, but easy...
owai
Post by owai »
so any other ideas where to get them from bar the Toyota garage? as i don't know the part number or even what im supposed to be looking for :(
