ERROR CODE 42
ANDY FINDLAY
ERROR CODE 42
Post by ANDY FINDLAY »
was driving mt tubbie there and just before i stopped my engine light went on i checked the ecu and it flashed out 42 i checked it up and says its speedo problem but every thing works fine any help please
GT Rich
Re: ERROR CODE 42
Post by GT Rich »
Andy what rev tubby do you have??
Rich
ANDY FINDLAY
Re: ERROR CODE 42
its a late rev2 mate any ideas
#-o
SIMON W
speedo
Post by SIMON W »
it will mean you have no speed input signal to ecu if your speedo is a cable there is a wire from the back of the speedo head wich runs to the ecu
ANDY FINDLAY
Re: ERROR CODE 42
its not a cable speedo its a electric one i fitted a delimiter chip not so long a go but dont think its workin and i am getting the error code #-o
simonb
Re: ERROR CODE 42
Post by simonb »
i have had this problem and the car went into a sort of safe mode.
i removed the dashed to exposed the circuit board with the delimiter chip and kph to mph conversion and discovered a dry joint on the circuit. quick touch up with a slodering iron and hey presto.
Kongaroo
Re: ERROR CODE 42
Post by Kongaroo »
Andy did you get this sorted out? Just wondering because I also have this error appearing...
What was the solution and how much did it cost to repair?
