[Mk2] [Turbo] Is this parts list good for 500-ish BHP?
redeye32uk
Re: [Mk2] [Turbo] Is this parts list good for 500-ish BHP?
Post by redeye32uk »
I run 255 on the rear but BFG drag radials on the strip on stock rims :thumleft:
450wbhp comming soon
Wingers
Post by Wingers »
Another question relating to big power builds is which revision engine to start with?
I'm aware of some differences between heads that meant the rev3+ can accept higher lift cams although the rev1-2 heads can be easilly modified so this probably isn't a big problem.
Also, the early rev3 blocks are meant to be thin walled but this was apparently corrected for later batches. Are there any other differences?
I'm guessing that rev4+ is the best option but rev1-2 probably aren't too bad (just need to sort out head). Rev 3 could be ok but i might end up with a thin wall version so a bit more risky.
Does that sounds right?
Are there any differences between rev1 and rev2?
Wingers
mr2readster
Post by mr2readster »
All this talk about thick wall, has anybody found out exactly what the actual differance is and does it make the block more reliable.I mean what is the actuall differance in thickness, is it micro mm or 0.5mm ](*,) .
redeye32uk
What you should be asking is is there such a thing as a thick or thin walled block at all :?: :!:
tonigmr2
Post by tonigmr2 »
Pretty sure that was confirmed by Dino some years back. He measured up his (failed) rev3 block and cf to a rev2, I can't remember the difference but he thought it considerable.
T
redeye32uk
I know someone who's been through 20 or so blocks including early rev 3's and can't find any noticeable differences. i've measured about 5 so far, we've got a topnotch ultrasonic scanner, and i can't find any difference what so ever so far.
tonigmr2
Post by tonigmr2 »
Need to find a failed one, I seem to remember it was suspected as a batch issue.??
T
redeye32uk
The 20 were failed blocks #-o
tonigmr2
Post by tonigmr2 »
LOL OK. Maybe a search might throw something up, but am positive it was Dino who first mentioned this. :-k
T
SFLee
Post by SFLee »
my builted engine is off a celica st205, and i believe they are slighty different but will fit mr2, am i correct to say , the thin wall is japan batch ?
and uk gt4 should be the thick wall type ? but then again, also the is some sticker L1 or something on the cam cover, anyone know what they mean ?
also just found a very good site about it ^^
infact too much to read
mattcambs
Post by mattcambs »
link?
SFLee
Post by SFLee »
Link dont copy and paste
but you can view it at
http://gtfour.co.uk/
under
What is ...
Thick 205 Cylinder Block
some tech data is there also \:D/
