[All] [Generic] Battery
SFLee
Post by SFLee »
what is best way to keep it alive ^^
leave it unplug ?
leave it unplug but charge it every month ?
keep it charge all the time ?
Hybrids
Re: [All] [Generic] Battery
Post by Hybrids »
Attach a trickle charger, ideally a 3 stage charger.
It will monitor the condition of the battery and top up the voltage as required.
You don't have to buy an expensive one, I have seen trickle chargers from £10 upwards, they typically are around 0.6amp, okay for keeping it topped up not really any good if your battery has been allowed to go flat.
Better 3 stage chargers wil charge a flat battery in a reasonable amount of time.
SFLee
Post by SFLee »
so keep it charge ? with a charger
or charge it
disconnect reconnet 2 week and charge etc
Hybrids
Post by Hybrids »
If you have a trickle or 3 stage charger then you can leave it connected all the time.
I use 2 different ones, a std trickle charger and a Ctek XS7000.
The trickle charger does it's job and keeps it topped up, the Ctek is a bit overkill for just conditioning it has other features suitable for AGM batteries and sulphation recovery.
MattMR2
Post by MattMR2 »
Consider one of those solar power trickle chargers off eBay for £12.
I've been using one for a while now as I don't drive my car during the week and it does the job. Best of all it doesn't cost anything to run. ;)
Grendel
Post by Grendel »
please remove posted in error.
FreeFall
Post by FreeFall »
I use an 'OptiMate' charger/conditioner for my bike - works really well and has stopped me having to by a new battery every spring ](*,)
Oh, moved to electrical by the way :thumleft:
Nick
Return to “Electrical”
