[Mk2] [Turbo] What is the best gearbox to use for high power?
bobhatton
Post by bobhatton »
I need to get a rebuilt gearbox with LSD and taller diff gears.
I understand the REV 2 and 3 are the best to use.
What is wrong with the REV 1 box and are the 2 and 3 the same?
What are the part numbers for the taller diff gears and what was the model and year of car they come from?
Bob
3sgte
Re: [Mk2] [Turbo] What is the best gearbox to use for high power?
Post by 3sgte »
i know the rev1 boxes had weaker syncro rings
SW20Paul
Post by SW20Paul »
iirc final drive from a st165 celica will give you a higher top speed.
bobhatton
Post by bobhatton »
SW20Paul wrote:iirc final drive from a st165 celica will give you a higher top speed.
Right, thanks.
And that gear set will fit in any box?
Bob
bobhatton
Post by bobhatton »
3sgte wrote:i know the rev1 boxes had weaker syncro rings
Thanks,
that is what I understand, but is that all? Can the later syncos be fitted into a REV 1 box?
Are the diffs all the same? I have a TRD LSD for a REV 1 I was told but will it fit in a REV 2?
Bob
JAP BOY
Post by JAP BOY »
Hello mate i think 3s Service centre sell these parts you require for your final drive!!!!! :D
Century Motorsport
Post by Century Motorsport »
JAP BOY wrote:Hello mate i think 3s Service centre sell these parts you require for your final drive!!!!! :D
We sell the final drive package - check our affiliates section.
Rev 1 boxes had single synchros and weak selector forks that were prone to bending.
Rev 2 onwards had dual synchros and uprated forks. Also, they were LSD as standard.
Regards,
Nathan
Builders of the the UK's first 9second MR2 - 9.722 @ 148 MPH ----- 07947883103 ---- www.centurymotorsport.com
Century Motorsport
Regards,
Nathan
bobhatton
Post by bobhatton »
Regards,
Nathan
Thanks Nathan.
So ALL Rev 2 have LSD fitted?
Is there anyway of telling from the outside if an LSD is fitted?
Bob
SW20Paul
Post by SW20Paul »
All REV3 boxes have LSD it was still an option on REV2 cars.
Best way to check is take a drivshaft out and look in the hole if it has a hex bar running through the hole then it has a LSD.
bobhatton
Post by bobhatton »
SW20Paul wrote:All REV3 boxes have LSD it was still an option on REV2 cars.
We have just changed a Rev2 box with a hex bar through the hole for a Rev 3 box with LSD. Now the wheels do not spin in 2nd up but before with the old box one wheel would spin, but from what you said the old box had an LSD too.
Its a bit of a problem to know when an LSD is fitted and working or not.
Bob
SFLee
Post by SFLee »
but for those power level, JJ bend his REV2 forks too ??
RyanRs
Post by RyanRs »
if it has a bar through the middle of the output shaft then it has factory viscous LSD.
from what i have come to understand from many LSD posts over many mr2 forums, you will not know whether you have an oem lsd or not from driving the car or spinning the wheels -you have to physically look for that bar in the shaft. the 'spin the wheel' technique wont work due to the lsd being viscous coupling -we could not put enough torque through the transmission by hand to activate the mechanism.
Chr15py
Post by Chr15py »
...or if you do a full bore launch (on a private closed road obviously) and leave 11s, then you have a diff :lol:
I think anyway...
Chris
Mr Rapey Banana WILL get you...oh yes! :)
