what oil??
HT
what oil??
Post by HT »
being lazy - what oil grade for the mk1 couldn't remember if it was 15w/40w or 10w/40w??
monkeymax
Re: what oil??
Post by monkeymax »
I believe the Toyota recommendation is 10W/40 (By the way - you don't have the second W after the 40 as the W helps designate the viscosity of the oil at low temperatures).
I've used 10W/40 just fine and currently have 5W/40 semi-synthetic in it...
3.5L should be enough.
HT
Re: what oil??
Post by HT »
Thanks Max - don't get too technical right now, just finished research plan hence the lazy Q!! :D
BIGBOBO
Re: what oil??
Post by BIGBOBO »
It might not be a great idea to use semi synthetic if it has been fed mineral oil for two decades.
I used semi synthetic and a week later I had three oil leaks (all hoses, easy to fix), mechanic told me it probably was because of the different kind of oil.
monkeymax
Re: what oil??
Post by monkeymax »
Good comment. Luckily I know that the owner previous to me was using semi-synth, and it wasn't leaking when I got it so I now just stick to that.
System-G
Re: what oil??
Post by System-G »
The AW11 should have always used semi-synth from day 1...
I think either your oil leak was due to too thin an oil or coincidence...
I have run semi synth on all my MK1's and some very thin motorsport oils on my track cars with little problems.
I sprung a leak in the crankshaft oil seal on my old track car shortly after using a 0W50 high performance motorsport oil. Seal replaced and the dizzy seal started seeping. Seal replaced all OK.
Because I started changing oil every 2000 - 3000 miles, I started using "No-Name" brand 10W40 - the cheapest I could find, but have since been experiencing oil pressure issues...
I now use fairly expensive 15W50 motorsport oil in the track car and Castrol 10W40 in the other N/A and SC.
HT
Re: what oil??
Post by HT »
System-G wrote:The AW11 should have always used semi-synth from day 1...
Hi Garrick - so it would have been a semi from dayone? The only past probs oilwise was using fully synthetic (Mobil 1) in my high mileage (and under maintained mk1a) - it developed a bottom end problem within a couple of months! :(
SuperRedMR2
Re: what oil??
Post by SuperRedMR2 »
I have always used 10/40 since owning my current mk1
Its 3.3 litres
HT
Re: what oil??
Post by HT »
SuperRedMR2 wrote:I have always used 10/40 since owning my current mk1
Its 3.3 litres
Handy that oil is increasingly being sold in 4 ltr sizes :wink:
midenginedmaniac
Re: what oil??
Post by midenginedmaniac »
I use comma Semi synthetic
User avatar
Lauren
Re: what oil??
Post by Lauren »
Surely from day one you'd use a mineral oil as back in the 80s you had to run cars in.
I'm not sure that there were that many semi-synths available 20 years ago. I know from my first MK1 with all the service history that it was always given Duckhams QXR... no idea if that was semi-synth or not.
SuperRedMR2
Re: what oil??
yeah they reduced it to 4 litre cans - handy - but keeping the same price is ridiculous
HT
Re: what oil??
Post by HT »
Hmm makes me wonder how much advantage in semi's over mineral's bearng in mind its nearly 19 years old and has done over 100k.
