the correct use for an ironing board
Is the PS3 better than a C64, all in here
User avatar
Lauren
Post by Lauren »
H3RB
Re: the correct use for an ironing board
Post by H3RB »
exactly how i set mine up :thumleft: :thumleft: its hieght adjustable and everything :thumleft:
SamUK
Post by SamUK »
that is quite clever!!
and there was me thinking it would be an animated picture of a 360 sliding across some clothes.
User avatar
Lauren
Post by Lauren »
SamUK wrote:that is quite clever!!
LOL!
Well actually it came about when i was trying to think of things i could mount the steering wheel to, so i had a look online and on some forum some guy mentioned using an ironing board.
It works well plus you can just lay it flat on the floor with the wheel still attached and plugged in. :+:
spudgun
Post by spudgun »
Good girl, Lauren :thumleft:
I did this at my mates house years ago, but didn't find the 'board was substantial enough. Moved around a bit.
All good though.
viperrr
Post by viperrr »
how have I never considered this before?
Genius! :clap:
nakamura
Post by nakamura »
Great idea Lauren! :thumleft:
Spittinflames
Post by Spittinflames »
Thats a good idea actually but i could imagine it moving quite alot.
If your well into your driving sims have you ever considered buying an empty arcade machine? They come with wheel, pedals and seat plus the cabinet. You can pick them up for around 100 quid.
Just remove the onboard wheel and pedals, stick your own in there... Mount your console in it, fit your own wheel and pedals and get a cheap 28"/32" lcd to fit inside. Hey presto jobs a good un. :thumleft:
Bender Unit
Post by Bender Unit »
Exactly how small are your clothes? That ironing board is tiny! Do you actually iron clothes? I can only assume its part of some kids play maid set? ;)
dazzz
Post by dazzz »
Ultimate in strength and ridgidity.
50mm sq galv steel box section with cast aluminium clamps.
The seat has speakers in the headrest and a sub in the back. Sounds and feels great.
Also, easily dismantled.
http://i273.photobucket.com/albums/jj22 ... ct0013.jpg
http://i273.photobucket.com/albums/jj22 ... eseat5.jpg
http://i273.photobucket.com/albums/jj22 ... ceseat.jpg
User avatar
Lauren
Post by Lauren »
Bender Unit wrote:Exactly how small are your clothes? That ironing board is tiny! Do you actually iron clothes? I can only assume its part of some kids play maid set? ;)
I don't iron clothes, well not more than a couple of times a year.
Return to “Games Consoles”
