[Mk2] [Generic] Rusting MK2 Sills, common problem.....?
milesy_boy
Post by milesy_boy »
Hi all, with all mk2's approaching a fair old age now, and with the British climate being what it is, It seems that a common problem is rusting sills?? There were 2 at my mechanics garage getting fixed,a 95 and a 93, and I had a close look at the sills. From the wheel arch onwards and they were starting to bubble, I had to get one sill welded for the MOT and the repair was a bit rough, now.... surely with all the talented people that are on this site, someone/people could make a complete full length sill that could be welded on. I know that cutting out the old sill and welding the new one in is not for the beginner, but I still think that a solution could be found and produced?? Ideas and opinions appreciated here as a bulk buy could be the way forward.
I think this is going to be a big problem for lots of people soon????
Regards
Miles
JAP BOY
Re: [Mk2] [Generic] Rusting MK2 Sills, common problem.....?
Post by JAP BOY »
I had both outer and inner sills changed mate got from MR T cant remeber the price but weren't too bad also had the wheel arche tunnel cut out and a new one put in and painted back to normal with 4 coats of under seal all in £2400 which in my veiw was money well spent to get it back to original !!!!
This was no cut out and weld abit of metal in i had all underseal removed from under the car to check if any where else was rusting up!!!!!
I got a verbal garantee that it would not rust up again!!!!
thebody
Post by thebody »
i thought the most common place for the mr2 to rust was the doors my sills are perfect and never really heard off problems with the sills before :-k
nakamura
Post by nakamura »
Naturally with age this happens, depends of a fair few factors. Has car been regularly cleaned, polished, garaged, repainted (well not regularly!).
Also some kits like the border can cause water to sit on the top of the skirts which can cause rust.
Everyone has a different story. But if it happens its easy to fix.
mrfil13
Post by mrfil13 »
it does seem to be a common problem. Depending on the state its in you can either get new sills or just rub them down a little, treat them and paint them again.
There are cheaper alternative sills that you can buy, dont know the models but some people have got them off nissans and fords.
The bottom of the doors is common as well, i just try and put some waxoyl on as soon as poss.
RST
Post by RST »
It's a common problem -there's been a few posts on it. I had 2 sets of full -length sill panels made to re-do mine (actually 2 separate steel pieces seam welded together in the middle on each side). If you botch it or do it on the cheap, you'll only end up doing it again, and again, and again.
JAP BOY
Post by JAP BOY »
Fair point that other makes of vechicles do fit but whats the point when they are cheap enough from MR T
mrfil13
Post by mrfil13 »
mrT when i got mine were about £50 for half a sill. From what i gather you can get the whole sill for less than that from other companies.
inky
Post by inky »
Opel Manta sills apparently are a perfect match.
As far as I have seen it always seem to be Nautical Blue H-plates that have bad sills. Or maybe it just shows up worse on them.
JAP BOY
Post by JAP BOY »
Cant really say its the blue which have these problems although i think earlier UK car suffered from this quite alot i've not seen any later Rev3 + cars suffering neither any imports!!!!!! :)
gerbil1028
Post by gerbil1028 »
waxol stuff does it have a max temp rating ?
i ask cause i want to treat and reaseal engine bay before putting engine in and the boot floor above the exhaust so wondered what it can cope with
