Compression Tester
Knightkiller
Compression Tester
Post by Knightkiller »
Quick question, a lot of the compression testers I have seen (Draper etc.) come with 14/18mm adapters.
That ok for the 4A-GE?
Ta Muchly :mrgreen:
dr_wilkinson
Re: Compression Tester
Post by dr_wilkinson »
Quick answer, yes!
ligertigon
Post by ligertigon »
try to find one that you can tighten satisfactorly down those deep recesses.
Otherwise you are spinning the rubber hose #-o IYSWIM
may then give false reading...
System-G
Post by System-G »
You only want to tighten to finger tight anyway - dopn't want to overtighten :wink:
I have a draper that I tighten using the hose and it tightens up just fine and readings are accurate.
Incidentally, Knightkiller, why do you think you need to use a compression tester? Problems?
cartledge_uk
Post by cartledge_uk »
if you have a air compressor, its probly worthwhile to buy a leakdown tester. much better than compression tester and can tell you a lot more.
Knightkiller
System-G wrote:You only want to tighten to finger tight anyway - dopn't want to overtighten :wink:
So I can tighten that draper one just by using the hose? Sounds dead simple then, prices are much better than I expected looking on ebay. The ones in Demon Tweeks are 90quid+ :roll:
No not any problems fortunatly -G-. Just got a long run coming up through the alps down to sicily in the '2 and I wanted to give the old girl the once over. :D
cartledge_uk wrote:if you have a air compressor, its probly worthwhile to buy a leakdown tester. much better than compression tester and can tell you a lot more.
Hmmm... not at the moment but definatly on the list for the future so will bear a leakdown tester in mind. Dont really want to go into to much detail though, just a basic check on the compression figures is good for me at the moment. :thumleft:
kevin..in
Post by kevin..in »
Knightkiller
Nice one Kev :thumleft:
