I take it the garage is out of action at the moment? Just got this.
Not Authorized
You Have Attempted To Perform A
The Site Administrator Has Configured The Garage Such That Your Combination Of User Level
toxo wrote:Nice work lads, that was a pretty quick recovery considering!
Just so you know..
Could not connect to smtp host: 111
: Connection refused
DEBUG MODE
Line: 114
File:
/home/imoc/public_html/forums/includes/smtp.php
When sending PMs..
this has now changed to a Relay Access Denied error so I guess this is one of the bits you're tinkering with!
Greddy-Matt wrote:Top job on getting the site back up again guys, stirling effort!![]()
I take it the garage is out of action at the moment? Just got this..
Not Authorized
You Have Attempted To Perform A'BROWSE' Action.
The Site Administrator Has Configured The Garage Such That Your Combination Of User Level& User Groups Are Not Allowed Perform This Action.
tonigmr2 wrote:Fear me, for I am watching
toxo wrote:Good luck getting that removed..
last time I was in that situation it took me 6 months to get our
/23 network removed from their list!
Speedy wrote:toxo wrote:Good luck getting that removed..
I'm not convinced it's a problem with AOL, but we shall see.
CosmosblueMR2 wrote:i seem to get this whenever i post a reply
Code: Select all
Dec 6 00:08:42 interae1 postfix/smtp[17741]: CF984FF26B: to=<[email protected]>, relay=mailin-03.mx.aol.com[205.188.109.56]:25, delay=1.8, delays=0.12/0.01/1.2/0.38, dsn=4.0.0, status=deferred (host mailin-03.mx.aol.com[205.188.109.56] said: 421-: (DYN:T1) http://postmaster.info.aol.com/errors/421dynt1.html 421 SERVICE NOT AVAILABLE (in reply to end of DATA command))
Dec 6 00:37:29 interae1 postfix/smtp[19280]: CF984FF26B: to=<[email protected]>, relay=mailin-04.mx.aol.com[64.12.138.57]:25, delay=1729, delays=1727/0.01/1.4/0.41, dsn=4.0.0, status=deferred (host mailin-04.mx.aol.com[64.12.138.57] said: 421-: (DYN:T1) http://postmaster.info.aol.com/errors/421dynt1.html 421 SERVICE NOT AVAILABLE (in reply to end of DATA command))
Dec 6 01:10:50 interae1 postfix/smtp[19494]: CF984FF26B: to=<[email protected]>, relay=mailin-03.mx.aol.com[64.12.138.153]:25, delay=3729, delays=3727/0/1.9/0.41, dsn=4.0.0, status=deferred (host mailin-03.mx.aol.com[64.12.138.153] said: 421-: (DYN:T1) http://postmaster.info.aol.com/errors/421dynt1.html 421 SERVICE NOT AVAILABLE (in reply to end of DATA command))
BenF wrote:
I'm just about to have a go at the Garage now.
