[Mk2] [NA] Steering Rack Play?
Cj82
Post by Cj82 »
Hi all
I have had my MOT on monday and i am told i have slight play in the ball joint on the offside of my steering rack
Can you change just the ball joint or do you need to replace the full rack?
Plus how easy is it to change?
Cj
Mr2GtBlue
Re: [Mk2] [NA] Steering Rack Play?
Post by Mr2GtBlue »
Are you talking about the ball joints on inner rack arms?
or the ball joints on the track rod ends?
or the ball joints themselves?
anyways all are fairly easy to replace and no you wont need to change the whole rack.
Cj82
Post by Cj82 »
it is the arms that come out of the steering rack where the play is think they are called Steering Control arms??
Cj
Cj82
Post by Cj82 »
http://www.ayrpark.plus.com/epc1/toyota ... _1993.html
Think it is part number 45503 on here that i need but can't tell if that includes the ball joint too?
Mr2GtBlue
Post by Mr2GtBlue »
If your car is non power steering you can get the full rack for 30 quid from here www.buypartsbuy.co.uk you have to send them your old one once youve recieved it.
Ive just ordered myself one :thumleft:
Cj82
Post by Cj82 »
unfortunatly its Power Steering :(
teccyjim
Post by teccyjim »
you get the ball joint which screws onto the PAS rack, the rod attatched to it screws to your track rod end (19mm),
Ive just done mine!
