jimi wrote:D reg will be a change over model and probably doesn't have the full central locking, it will be as"omracing" described.
I looked at the diagrams before for someone else and the problem is that the early cars don't have the switches built into the door locks the same as the later cars, if I remember correctly the wiring and the relay are also different, so it's quite a big job to convert to the later system.
A much easier way to do it is to buy a universal remote central locking kit, you can pick them up on ebay for
£20/30,
and interface it with the door lock button.
HTH
Jimi
GunZ wrote:if you have the switch on the drivers door panel to lock doors from inside you do have c/locking,
HT wrote:If it helps i replaced the drivers side door on my mk1a with one from a mk1b ad instantly got full central locking.
