I have owned her since February, it was imported in 1998, has 143,000 kms on the clock.
Taxed and Mot'd till 31/01/08 although the car will come with no tax!
Car is straight and true, only minor cosmetic marks through age really.
There will be two new tyres put on the back so all tyres will be legal, new front pads were fitted within the last fortnight although they did recommend new front disks too.
Inside is usual GT spec, air con
Tbar blinds are present, no bags though.
Comes with a nice Mongoose twin exit stainless exhaust
Ngk platinum sparkplugs
Manual boost controller
Fuel cut defender
Huge k@n cone filter
Toad alarm and fob, not sure which spec but does the job!
I have religously changed the oil every 3-4000 miles and repaired whatever needed doing,
The car came with no service history and still has no history
The engine runs sweet, starts first time, is always driven off boost until temp is right, and engine allowed to run before switching off, the usual precautions!
When temp is up, the car pulls strong as it should with no strange noises/knocks from the engine.
Please, if you live nearby or fancy a test drive my mobile number is 07791856339.
The only bad things i can say about my car are,
the above mentioned cosmetics
I think the suspension is too hard
the suspension squeeks sometimes
If these are classed as problems im sure they will be reflected in the price.
Any questions ask away, please PM me with your offers if you are interested or post your comments/valuations if you're bored!!
Thanks,
Gareth
