cam is easy enough, its the reshimming dude where the time and money goes.
simmo490 wrote:you should be able to run more that 13psi??
i dont think the ecu throws the injector cycle to 100% after 13psi??
i had basically the same mods as you with a fuel cut defender and was running 1.1-1.2 bar with no problems.
granted the injector cycle would have been pretty high but as long as i did not take he p1$$ with the boost(or get spike) everthing should be ok
simmo
Redmr89 i'd have your emissions checked as that might highlight whats happening or where your Horses are escaping!
Check for error codes also mate or your O2 sensor or Airflow meter which doen't go alot but check these and see what they bring up!
Good Luck and let us know how you get on!
JAP BOY wrote:1.2 or 1.3 can in my veiw can only be done for short times dont do it too often though!
