[Mk2] [Turbo] clear cam gears cover,couldnt buy one ,so i made one.
planted1
Post by planted1 »
As above really,
took half an hour,
perspex cost a fiver.
not perfect,but when i have the cams dialled in it should give easier access.
be brutal,cut,cut,cut
jigsaw does the trick
not perfect,but not too bad.
screw holes are a bit close to the edge,but should be ok.
McBride
Re: [Mk2] [Turbo] clear cam gears cover,couldnt buy one ,so i made one.
Post by McBride »
That is very nice any chance of a tutorial? im not all that clued up with this,
raptor95GTS
Post by raptor95GTS »
nice job :clap: It's good to see when someone does this kind of thing rather than buy something expensive and bolt it on. Not my kind of thing but fair play for doing it
Spittinflames
Post by Spittinflames »
That looks really good. :clap:
klx_boy
Post by klx_boy »
Well done, looks really smart!
draz1k
Post by draz1k »
top marks mate,
plus gives you a chance to show off the purple behind :D
planted1
Post by planted1 »
Thanks for the encouragement fellas :thumleft:
Ive still to get a bit of sticky backed foam seal,and some tubular spacers to go between perspex and cam cover,as a bit of support.
Yeah,the bits behind are nice :D
