[Mk2] [Turbo] apexi adjustable coilovers
is it easy to adjust them,
the car is to low down to the road on 16"s
Re: [Mk2] [Turbo] apexi adjustable coilovers
depending how old they are its easy, if there quite old
a night before spray them with WD40 or a penatration oil,
then jack the car up, there are two locking rings, using a C spanner
(i have spare ones if u aint) just unlock these and adjust them DOWN to have the car higher, once you have adjusted them lock them off again
simmo
simmo
Adjusting apexi coilovers is quite easy aslong as the locking nuts are free and you have got the locknut spanner.brown snake wrote:is it easy to adjust them,the car is to low down to the road on 16"s
cheers for info i haven't got a c spanner(lock nut spanner) the car has the coil already fitted how much would a garage charge
it really is
a DIY job mate unless u got money to burn
simmo
simmo
hi where do u get the c spanner from, my cars that low down i can't even go near a speed humps etc and the steering feel really heavy at times hard to turn left and right but no lights come on dash
How rare not seen Apexi coilovers for a long time-top notch
Let us know how you get on with the adjustment
