Firstly must say a big thankyou to Peter at SBITs for some very last minute help in changing out a faulty thermostat the night before I was due to drive down to Hoddesdon which is some 3.5 hours drive away from me.
Must also say the guys at Perfect Touch are all really friendly people and certainly know there stuff! I will definately go back there again after I start building the engine for bigger power
Anyway some good results
My Blitz ECU was mapped for a smaller CT20b on 540cc injectors.
The car was dyno'd on the Blitz ECU first and managed 314 HP at the wheels!
Rob also found out the ECU's Rev limit was raised to 8500rpm, LOL.
He also said that generally the car was running fine.
I figured after all that driving I may as well try and see what the maximum safe power was with the PowerFC and at the same time trim the injector duty cycle down a little to a slightly safer figure
The PowerFC yielded slightly less power
Dyno charts are here:
Another interesting thing is the drivetrain losses were only 7 to 8 percent
The Dastek Dyno uses coastdown to calculate drivetrain loss so not so good for pub bragging rights
Only 1 problem which is I am getting a couple of slight misfires occuring during 2nd and 3rd gear full throttle pulls to the redline
In any case I am not too bothered about getting this rectified right at the moment as I am planning to remap for larger injectors anyway sometime soon but will ask Rob to double check the innovate AFR logs at full throttle before I drive all the way back home when I next go there for mapping, lol.
All in all I am happy with the results
